Question bout my setup
Old Jul 23, 2003
iceman's Avatar
--< GripSpeed Member >--
Hey wassup...recently i purchased 2 kicker L5 and a box for 175...the box however was made for 3 kicker L5 so i decided to just cover up the middle hole where the L5 goes with my avionix 440.4 amp...after gettin everything wired up and installed..the subs sound a lil weird and does not hit as hard...anyone know wut the reason may be..and if i do buy a 3rd L5 sub..wut kind of amp should i get...is there such thing as a 3 channel amp or no
Old Jul 23, 2003
LudlamTheory's Avatar
i boogie for the raindrops
is teh box a common chamber? is there a divider between the subs?
Old Jul 23, 2003
fonto's Avatar
The LA Clipper
What happened to the other Kicker? ...and yeah, are there dividers between the chambers. Instead of buying another kicker you could always buy a Ported pre-made box (which are REALLY easy to find for Solo Barics) or you could build your own. A ported two will prolly hit harder then 3 in a sealed. Does your amp have a subsonic filter on it (really important if your gonna run ported).
Anywayz, you have other options besides buying another Kicker or another amp. I would try the low cost options first and see if it works.
If you need help finding stuff let me know and I will help you find a box or tell you where I got the wood cut to build my own box.
cukaracha
Aug 27, 2015 02:02 AM
Strycker
Aug 2, 2015 08:40 PM
Theshwartz35
Jul 17, 2015 11:13 PM
