alarm/keyless entry
Old Jul 21, 2003
RS4DUKE's Avatar
RS4DUKE is an unknown quantity at this point
alarm/keyless entry
Hey i'm new here, my questions is does anyone have a colored wiring diagram for an alarm/keyless entry system. I saw the chart in the diy but I'm trying to find a better one. Any help would be great, thanks.
Old Jul 22, 2003
RS4DUKE's Avatar
i could really use some help guys, please, thanks
Old Jul 22, 2003
Blkopz's Avatar
Blkopz is an unknown quantity at this point
Hey bro,
Is this the stock honda transmitter or is the the generic DEI Automate 410 they use sometimes? In other words, what does your transmitter on your keychain look like. I had the automate installed in my civic and probably can get you the info.
Lee
Old Jul 22, 2003
Blkopz's Avatar
just found this under DIY section bro, here ya go:
http://www.7thgencivic.com/modules.p...howpage&pid=18
Old Jul 22, 2003
RS4DUKE's Avatar
thanks man but as i stated in the first post that i was kind of hoping i could get something alittle more useful than the diy. by the way it will be an aftermarket system, but i appreciate your help bro
Old Jul 22, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
sorry dude, that's dei's tech sheet for our cars, it doesnt get any better then that. If you cant read that then you shouldnt be attempting an alarm on your car. Although whoever copied that neglected to copy the notes on the bottom, so there are some holes in it i can tell you what most of them are right now:
*1 - the factory alarm plug is a green plug in the driver's kick panel and is present in all cars, regardless if they have a factory alarm or not.
*2 - you will have to diode isolate each door pin : The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white.
*3 - In the top left plug
*4 - the tach test connector is located in the engine compartment on just to the left of the battery, it will be by itself and have a wierd little plug on the end of it.
*5 - you arent going to need a speed sense regardless
Old Jul 22, 2003
RS4DUKE's Avatar
thanks dude, im not saying i cant do it with that chart i was just hoping to get something alittle more like a diagram or something, those notes will defidently help, thanks man
Old Jul 22, 2003
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
Try an auto sound place that does a lot of alarm installs, maybe they have a copy of one or what not. Or try searching the net, i found a really detailed/color coded one for 5th gens a while back when I did my friend's stereo in her '94 sedan.
Old Jul 22, 2003
RS4DUKE's Avatar
thanks bro
Old Jul 22, 2003
bzrollin's Avatar
I completed the notes above, but like i said, I WORK AT A CAR AUDIO SHOP, this is the most information ANY shop will have, and is plenty of info to complete ANY alarm install!!! If you cant look at your alarm's instructions and then at the DIY and can't figure out what wire goes where, YOU SHOULD NOT INSTALL YOU OWN ALARM!!!
Old Jul 23, 2003
RS4DUKE's Avatar
Ok bro, man I got you the first time, thanks for the notes, if I see that I can't do it I wont but I dont think I will have a problem for I have hooked up several different electronics in my car, later
Ziggy1999
Oct 15, 2015 07:56 PM
Donahue
Sep 8, 2015 09:00 AM
sbi
Sep 2, 2015 07:44 AM
henrytn
Aug 11, 2015 10:01 PM
bizspeed
Florida
Jul 14, 2015 08:40 PM
