Wiring up an On/Off LED?
Ok I had a toggle switch installed that activates my aftermarket fog lights and I was wondering if I could somehow wire in a simple red alarm LED to indicate when the fog's are on/off since mine come on whether or not the headlights are on. Do I just tap the LED'
s pos/neg wires into the switches or what??
after the toggle switch splice the wire and put in a 1k ohm resistor ran in parallel with your fogs, then run put an led in series connected to ground after the resistor
12v----V-----fogs
...........|---resistor--led--ground
the v is the switch
12v----V-----fogs
the v is the switch
sch2cm
Jul 21, 2015 09:58 PM
robbie374
Jul 7, 2015 02:56 AM
