amp wiring kit
Old Jul 20, 2003
hoho's Avatar
hoho is an unknown quantity at this point
Question amp wiring kit
i'm new here. does anyone know what kinda amp wiring kit that i need to get for my amp? i jus bought a Rockford Fosgate Punch 801s but i do not know which wiring kit i have to buy. the seller recommended a 4-gauge wiring kit wit a 60-amp fuse but other sellers selling the exact same amp recommended an 8-gauge wiring kit wit a 60-amp fuse. what's the difference? which one do i have to buy for better quality? one more thing....i've seen some Rockford Fosgate 4-gauge wiring kits but they have a 50-amp fuse. will that be alright for my amp? can anyone also tell me if i should jus buy any wiring kit on ebay or go wit the brand that made my amp?
Old Jul 20, 2003
doubledeuce2k2's Avatar
buy any amp wiring kit, unless you care about the name of it. for subs, there is no significant gain made by paying more for a name brand amp kit. sounds dumb, but walmart has about the cheapest amp kits, and they work just as well as the overpriced branded ones. you will definitely want 4 gauge wire for your amp, thats a pretty good sized amp and 8 gauge won't really cut it. as for fuse, get whatever the kit comes with, if you blow it with loud music than just get a bigger one. 50 might be a bit small, 60 or 80 should be fine.
Old Jul 20, 2003
Logan3024's Avatar
RF makes a nice kit. Very nice connectors. I seen the Walmart brand before its called RoadGear, looks cheap as hell, the rca wire are chezzy as F@#$. It all depends on what YOU want. I believe the 801s uses a 80 amp fuse. What ever size fuse the amp has, run the same under the hood. (im assuming you are using 1 amp)
Stinger is a brand that offers nice connectors/fuses/wires at a decent price.
Old Jul 21, 2003
alex053's Avatar
please use at least 4 guage.
Old Jul 22, 2003
hoho's Avatar
hmm....do u know where i can check out the stinger brand wiring kit?
i'm thinking about getting the rockford fosgate wires but i'm not sure...but thanx for the help guys
Old Jul 22, 2003
MadWheel's Avatar
Premium Boosted Member
RF is great, I use it, def run 4AWG. Monster Cable is also pretty nice. Either way, 4AWG, and a capacitor will help out as well.
Old Jul 22, 2003
LudlamTheory's Avatar
i boogie for the raindrops
cable is cable, wire is wire, its all made out of metal. for your power and ground wire i'd use the walmart 4 gauge. for rca's you dont have to spend all that much, but at least get some shielded ones
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
jru27
Jun 19, 2015 03:51 PM
Lopes101
Jun 7, 2015 08:04 PM
jackoncruzpr
May 24, 2015 12:24 AM
LuvMyCivic
Dec 12, 2001 10:02 PM
