should i go ported?...
Old Aug 6, 2003
  #31
slick's Avatar
that little dude
slick will become famous soon enoughslick will become famous soon enough
they have 2 recommended sizes, medium = 1.65, small = 1.2.
is a 1.2 cube ported box the same size as a 1.2 cube sealed? or is it bigger because the ports aren't calculated into the size?
one of the things is that i still want a useable trunk, its not that large to begin with, but even now, i find myself using the cargo net, the space beside the box, and then the back seat.
Old Aug 6, 2003
  #32
LudlamTheory's Avatar
i boogie for the raindrops
jeez.. youre running the sub in 1.5 cubes sealed and they reccomend 1.2 cubes ported?
now i know why you blew it in that box... the sub handles 1200 at .55 cubic feet or so... the bigger the box, the lower the power handling of the sub...
i would personally go with the 1.6 cubic foot box tuned to 33 hz...
Old Aug 6, 2003
  #33
oh, and the ported box will be slightly bigger, but not SO much bigger..
Old Aug 7, 2003
  #34
slick's Avatar
that little dude
hot damn, i never even thought that the box size would have something to do with my sub blowing.
here is a pdf of the specs on the TDX, i really dont understand it much, but from i get, it says that if i go ported with the 1.65 cube box, it should be tuned at 33hz, and i should run 900watts to the sub. but if i run 1.2 cube, still use 33hz port, but 1200 watts on the sub.
here is the pdf: http://students.ou.edu/P/Mitul.Patel...anual_rev2.pdf
i know you can make some sense of it.
Old Aug 7, 2003
  #35
ive seen it...
do the larger box with the lower tuning, but keep teh gain silly low
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Sep 27, 2015 11:33 AM
Michelle2006
Sep 19, 2015 06:09 AM
Dave Brabant
Sep 12, 2015 08:39 PM
99BoostedSi
Sep 7, 2015 04:49 PM
