Ps2
Old Jul 14, 2003
2k1civicExCoupe's Avatar
2k1civicExCoupe is an unknown quantity at this point
Ps2
what do i need to hook up my ps2 to my Pioneer AVH-6400CD?? Where can i get whatever it is for cheap?? any help is always helpful.
Old Jul 14, 2003
Yukonart's Avatar
Yukonart will become famous soon enough
All you need is a set of the supplied AV cables that come with the PS2. For $10 or $15 you should be able to find a spare set to keep in the car, too.
They'll just hook up to the AV inputs on the back of the deck, so having that spare set in there hooked up at all times would probably be a great idea.
Old Jul 14, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
You also need a power inverter if the PS2 isnt already installed in your car.....
Old Sep 4, 2003
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
i have the same head..but wen i install my ps2 to the tv. the tv have alot of static..would u know a way to fix that?
Old Sep 4, 2003
PopcornPlaya's Avatar
Electric Boogaloo...
i believe there is some kind of jumper wire (can't think of the name of it) for pioneer decks to connect audio inputs to the auxillaries. i know my deck (premier deh p740mp)has to have one
Old Sep 4, 2003
WhiteRabbit's Avatar
check the video type whether its PAL or NTSC, it might make the difference
im not sure if the CD has *real* auxiliary inputs or the fake ones that all pioneer radios (the regular ones) have. If it has the fake lame ones, you need a specific RCA input P-bus connector, it simulates a changer and accepts any RCA input, whehter it be your mp3 player, minidisc, computer, or ps2.
Old Sep 4, 2003
AlpineCivic's Avatar
it may be the output of the PS2 thats causing your problem. The output may be to much for the headunit's input and may cause the signal to clip, try using an atenuator(spelling?) of some kind usually made for subwoofers so that the signal can be turned down a bit.
Old Sep 5, 2003
LudlamTheory's Avatar
i boogie for the raindrops
well... you dont NEED an inverter. you could wire up a 12v zener diode with a polarized and a nonpolarized capacitor and get a regulated 12v supply to hardwire into the ps2 and skip the onboard power supply.,,
Old Sep 5, 2003
Mystic3030's Avatar
lease:
Old Sep 6, 2003
seijin_av's Avatar
seijin_av is an unknown quantity at this point
can you explain this a little slower? i wanna hard wire a dvd player to my car if thats possible
Old Sep 6, 2003
baasically, a car electrical system isnt stable at 12 volts. what ludlam's system does is take any voltage at or above 12 volts and regulates it so its a constant 12 volts, so you dont get PS2 frying power spikes.
i dont know if it will shut off yrou ps2 when you get a sub 12 volt drop.
howeer, any electrical engineer can help you design one, if there isnt a problem below 12 volts, id expect lud to be cranking these things out and selling them for less than it would cost to buy a power inverter up in here
Old Sep 6, 2003
i would, except i dont have a ps2 to test with...
Old Sep 7, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
I have the same HU too and had the same problems your having. What I found was that my inverter was low quality (crappy shielding on wires and inverter itself causing interference) and subwoofer wires too close to video input in back of HU causing additional interference. When I upgraded my inverter from a Jensen to a Jazz inverter it got rid of most of the lines/interference on the screen. Then when I isolated my subwoofer wires and re-routed them away from my ps2 cables the interference went away, although sometimes I do get some interference, but it's very rare and very minor compared to before.
Old Sep 7, 2003
JohnDoe's Avatar
JohnDoe is an unknown quantity at this point
It's not the HU it's the PS2. For some reason the PS2's power supply is very noisy. It's happened with a bunch of the PS2s we've installed. Haven't really found a good reliable fix for it yet, though it seems to be the older ones that do it.
Old Sep 7, 2003
look above at my zener diode plan... it would completely eliminate the ps2 power supply
Old Sep 10, 2003
bboysushi's Avatar
bboysushi is an unknown quantity at this point
uhh what kind of jumper wire is this?
is there a brand name/unit # i could get?
I knew something was wrong when i plugged it into the aux input and had no sound..
I have a premier 740mp too
Bboysushi
stillmatik23
Jul 12, 2003 09:42 PM
