NEED QUICK ANSWER: Installing rear 6x9s in 7th Gen Question
Rep Power: 0 NEED QUICK ANSWER: Installing rear 6x9s in 7th Gen Question
I am installing new speakers in my girlfriends civic. She has a 2001, 2 door EX model. I already installed the front speakers no problem, but I can't seem to get the back trunk deck panel off. From inside the trunk, I undid all of the white clips, and trid to pop it off from inside the car, but I can't seem to get it. Is there more I need to do? How do I get to the rear 6x9's so I can take them out? Her car is sitting in my driveway and we need to get it done, so I need a quick answer! THANKS!
The LA Clipper
Rep Power: 322 You need to take the back side panels of to get the rear dash off (perferably both, but it is possible to get it off just taking off one of the panels). The side panels hold the rear dash down. Also, you need to take out the back seats to get out the side panels.
Also, most aftermarket 6 by 9s will hit the trunk spings, just so you know.
Rep Power: 0 hmmm ok, i guess ill take it to my friends stereo shop. it would be alot easier to finish there compared to in my driveway... thanks guys
Electric Boogaloo...
Rep Power: 304 seats come out, side panels come out, then the deck lid comes off, and yes, it is a bitch to do... there was a DIY at one time, but im not sure if its still there... be prepared to do some in car gymnastics to get it if you are a taller person (i am 6'1")
Rep Power: 291 From a diy thread i posted a long time ago...this is straight from crutchfield's install instructions. If you want some pics, I can post them too.
1. Remove one (1) 10 mm bolt from space between center of seat bottom and seat back cushions. Pull front edge of seat bottom upward to release hooks and remove (Figure 1).
2. Fold down both rear seat backs. Fold back carpet flap on back of passenger's side seat back. Remove two (2) 10mm bolts from seat bracket. Lift section of seat back and pull to remove (Figure 2).
3. Remove one (1) 10mm bolt securing seat bracket. Lift seat section and pull to remove.
4. Pry out both pillar rimpanels starting at the top. Continue prying downward to release and remove.
5. Remove two (2) 14 mm bolts from seat belt guide on passenger's rear side panel. Remove guide (with belt) and lay aside (Figure 3).
6. Pry open screw cover behind grab handle and remove one (1) phillips screw from opening.
7. Remove one (1) push pin retaining clip from rear side panel located near wheel well.
8. Starting at the rear of passenger's rear side panel, pry out panel and work toward door opening to release and remove.
9. Pull to release three (3) plastic fold-down clips on front edge of rear deck panel (Figure 4).
10. From inside trunk, disconnect brake light wiring harness located under rear deck.
11. Starting on passenger's side, work hands under rear deck panel to release clips. Work across panel. When clips are loose, work panel toward passenger's side. NOTE: Lift driver's rear side panel to work deck panel from under side panel. Remove rear deck panel.
12. Remove four (4) 8mm screws securing speaker. Pull out speaker, disconnect and remove.
13. Connect speaker wiring adapter of replacement speaker to vehicle speaker connector. Secure new speaker with screws previously removed.
14. Test speaker operation and reassemble rear of vehicle by reversing disassembly steps.
pheaton
05-04-2015 08:26 PM
