Alternative Amp Wiring for Sedan?
Old Jul 3, 2003
dma001's Avatar
dma001 is an unknown quantity at this point
I did a search, but I did not find a reference to the thread I was looking for.
I seem to remember someone posting that he/she had actually run the amp power wire along the route that is normally used for installing the OEM fog lights: the wire is routed from the battery through the passenger-side fenderwell and into the passenger compartment via a grommet near the front passenger door. (I am using the OEM foglight installation instructions from handaacessories.com as a reference)
The reason I was considering this method is that I'm a bit concerned about using the "wiring harness boot" in the firewall; I'm a little worried that the hole in the boot might tear and widen over time, letting dirt and water into the wiring.
Thoughts?
Old Jul 8, 2003
CelCUs's Avatar
CelCUs is an unknown quantity at this point
I ran my power for my amps and the power wire for the neons under my seats through that grommet and just electrical taped the *bleep* out of it on the inside and in the engine bay. When I rewired my system that was the first thing i did because I didn't like my power wire running across the engine bay all the way to the driver's side.
Old Jul 11, 2003
dma001's Avatar
Well, just an FYI for anyone who may be interested:
I finally did my amp/sub install yesterday, and the alternate power wire routing worked out beautifully. There is a "lip" of sorts in the wheel-well that the power wire fits into nicely.
There are actually two plastic grommets that lead into the passenger compartment via the glovebox. I reused the the grommet closest to the cabin (instead of discarding it as the instructions say) by cutting a hole in it and running the power wire through it -- worked great!
Old Aug 23, 2003
wolfman's Avatar
wolfman is an unknown quantity at this point
Just FYI ... these same two grommets/holes are also available on the driver's side inner fender, closer to the battery They are located right above the hood release cable. One of them is used by a wiring harness (on the 2003 Civic Hybrid), but the one closer to the cabin is empty = available for power wire route into the cabin
jtdunn4life
Oct 27, 2015 03:33 AM
jbdewitt
Jun 16, 2015 01:36 PM
jackoncruzpr
May 24, 2015 12:24 AM
smmahan
Apr 15, 2015 08:17 PM
OPGForce
Feb 7, 2002 09:43 AM
