System Install = SRS Light "ON"?
Old Jul 1, 2003
tcostello3's Avatar
tcostello3 is an unknown quantity at this point
O.k. I've installed dozens of systems in lot's of cars including my last 5 Hondas. Got this new 03 Si for the wife and decided to hook it up. Install consisted of the following:
Alpine 9811 Head Unit (Requires Battery Connected Power)
Sony Amp
Infinity 12" Reference in a Bandpass Enclosure
Everything went great..Sounds great! Had the Center Console Out, Back Seats Out, Front Passenger Out.
Ran 4 guage power fused for 60amps which is proper for this amp and head unit on one line. Distribution of 8 guage 1 to amp & 1 to receiver.
Got good ground in the wheel well area.
Now the $10,000 question is WHY THE HELL IS THE SRS LIGHT ON
Any tricks or experiences with this?
Thanks in advance
Old Jul 1, 2003
AlpineCivic's Avatar
Well, all 2001 and above Civic's have a connection on the factory seats that goes to the SRS Airbag system. If you disconnect any of the SRS connectors in the vehicle and turn the power to the vehicle ON the light comes on letting you know that you have or had an open SRS circuit, you can reset it though! there is a DIY on this website all you have to do is search!
Old Jul 1, 2003
evilone's Avatar
The Nightraid crew - Sensible Ownage
evilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the roughevilone is a jewel in the rough
DIY: SRS Light Reset
Hope this helps!
Old Jul 1, 2003
tcostello3's Avatar
Sweet! Found It, Printed It..Waiting on the car to come home so i can DO IT!
Thanks-A-Lot
Old Jul 1, 2003
tcostello3's Avatar
One More Thing......
If i read the replies right: Whenever I have a SRS connection broken make sure I don't turn the ignition. Pretty much leave the battery disconnected if dealing with SRS.
Just a little preventitive type question. Hate to make the same mistake twice..people should be punished for that!
Thanks Again SR Members!
Old Jul 1, 2003
alex053's Avatar
mine came on after i had my seats out to run wire for my amps and turned the key on.
Old Jul 1, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
Yeah, it will only come on if you have the seatbelt plugs or airbag plugs disconnected and you turn the car on. Takes a meere 15 seconds to fix though, not a big deal. I used a paperclip to do mine.
Old Dec 29, 2003
Crackhead79's Avatar
Talking It worked!!
Thank you so much everyone for the DIY to reset th SRS light. Mine came on for no reason and I wasn't about to go to the dealer. Took me three times too, but the paperclip worked fine. Thank you so much you are all great!
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
viper775
Nov 15, 2001 10:54 PM
artychris
Nov 11, 2001 10:23 PM
