JLAudio VR Series 6" speaks
Old Jun 26, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Hi guys, I have a set each of JLAudio VR600CSi and VR600CXi (component and coaxial respectively) sitting in a box in my closet. I want to install them in my sedan, and I know they are 6" vs the stock 6.5". Thing is, reading up on them in the JL site, I get this:
A premium coaxial upgrade for vehicles that accept a true 6-inch speaker. A perfect fit for many Japanese cars that won't accept a true 6.5-inch speaker without modification. The basket features three and four-hole patterns that match up with all factory mounting locations.
Has anyone installed these successfully? I'm gonna do it after Darknights anyway, but I was just wondering if I'm in for a long battle or a quick drop-in. If anyone has any experience with this particular line of speakers, please share your input, I will reward you with hot Asian ****!!! Thanks!
Old Jun 26, 2003
fonto's Avatar
The LA Clipper
Even if it doesn't fit you can most likely find an adapter from a compay like Metra or Schoch (*sp). Or you could cut out some MDF...because you will need a spacer anyway.
Old Jun 26, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
I have those components in my front doors and, just like anything else, you're going to have to get a spacer for it to fit, either a bought one or a homemade one, but you're not going to have any unusal problems with the front, now in the back may be a different story, but a 6 is pretty close to a 6.5, so you should still have enough lip to screw into the rear deck.
Old Jun 26, 2003
TeLLy's Avatar
Thanks guys!
Old Jun 27, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
You'll probably need a spacer for the front set, and you'll have to drill holes, but thats easy. Those won't mount the same was as the stock speakers.
Old Jun 27, 2003
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
Re: JLAudio VR Series 6" speaks
hahahaha, you're most likely going to have to get some sort of adapter no matter what. Ebay would probably be your best bet for that.
Old Jun 27, 2003
TeLLy's Avatar
Thanks, please let me know where I can send your ****.
Old Jun 27, 2003
BlessedAggie's Avatar
BlessedAggie is an unknown quantity at this point
you might have to cut
Old Jul 28, 2003
TeLLy's Avatar
OK this is what I ended up doin:
For the rears - just removed the rear deck (easy as pie, I dunno what everyone's been stressin over), unscrewed the old speakies, and popped in the new ones. Since they didn't fit perfect, I used 2 of the 3 mounting holes, took the OEM mounting screws, and put nice wide washers on them. I screwed down the mounting screws and the washers held the speakers nice and tight. Very satisfied there.
For the fronts...this took a little more work. When I found those craptastic speakers had the mounting "rings" integrated in, I flew into a murderous rage and kicked a paint can. I then took an Xacto knife and ripped the stock speaks to shreds. An idea then hit me (lightbulb flickered on above head) - I tried to screw the new speaker in using the old mounting ring after dremeling the old speaker out. That way I could use the same stock "clip" setup. No luck there, as I ended up breaking and chipping pieces off of the very brittle plastic Honda uses. At this point I was mucho pissed off, and was cursing the mighty Acura name. Then I stepped on my tube of automotive goop (i was custom-mounting some neons at the same time) and had another idea. I used the stock speaker ring and auto-gooped the speaker to it. After about 45 minutes the ring was sturdy enough to mount in the door. Voila! Custom speakers!
Old Jul 28, 2003
Regularjoe's Avatar
Regularjoe is on a distinguished road
I was so going to flame you for reviving an old post.
Haha.
Cool, sounds good. If installing was so easy everyone would be doing it.
krazykoncepts
Sep 8, 2015 09:02 PM
naokigoffi
Aug 30, 2015 06:19 PM
