Springs
Old Sep 7, 2019
Derek Sholes's Avatar
Derek Sholes is an unknown quantity at this point
Springs
I'm planning on getting my civic lowered. I just need to know how much I should drop for front & rear to be on the safe side from scrapping?
Old Sep 7, 2019
Re: Springs
Conservative 1-1.5" drops usually good to go
what year/trim do you have?
edit: was lowered with tein s-techs for a while on my 2002 (1.3/1.4" lowering F/R) with zero issues. Then I lowered with Tein SS-P coilovers, about 2-3" lowered (lowering is approximate it was about an inch above the lowest adjustment), and had minimal issues. Only scraping I had were on steep driveways and big speedbumps, and even then those scrapes were fairly inconsequential. I was able to take it down a dirt road to a local shooting spot, if that helps at all. It really depends on the kind of roads you're gonna be driving on regularly
Old Sep 7, 2019
mac25's Avatar
Dr Krieger of Modification
Re: Springs
The exhaust is the main low point. You can have an exhaust shop weld it up higher, and drop quite low.
You can also run square tubing on the exhaust, if you want it hella flush. (Not the safest for driving around town though, any slight hills/drive ways will scrape)
Old Sep 7, 2019
Re: Springs
Ok. 1.2 in F & 1.5 in R is what I was planning on. Would that be good? I have 14 civic sedan ex.
Old Sep 7, 2019
Re: Springs
Looks like twin s-techs will give you about the drop you want. 1.6/1.2 F/R. Couldn't tell you why they drop the rear more, but that's how they spec them, but that's how it is. P/n SKHC8-AUB00. About $200
Eibach pro kit (p/n 4087.140) gives a 1.2/0.7" drop F/R. About $250-300
Old Sep 11, 2019
Re: Springs
Why drop so much for Front?
Old Sep 11, 2019
Re: Springs
Ok thx. That's the measurements that I'll will probably go with. I just want to make sure that I have enough gap so that I won't rub.
Old Sep 11, 2019
Re: Springs
My guess: because racecar. Lower the front more than the rear forces more air above the car than below the car. Thinking of your car as a wedge, if air is blasting the top more than the bottom, it's gonna kinda produce more downforce. On the flip side, it's gonna create a faster moving stream of air over the top of the car and produce lift (think airplane wing). Honestly, looking at the big picture, it's all for the look. No street modder is really gonna think of it that hardcore.
Honda05
Jun 23, 2008 12:34 PM
tapdat48
Jul 25, 2006 08:54 PM
GreatWhite02
Sep 30, 2005 06:33 PM
03CivicEX4Door
Jul 9, 2005 05:15 PM
Ballatician
Aug 2, 2004 11:55 PM
