2013 9th Gen Full Suspension for Highway.
Old Feb 20, 2019
9THGenHighWay's Avatar
9THGenHighWay is an unknown quantity at this point
I drive like 25k highway miles per year and like 35k total. I drive about 85mph on the highway. I bought the car with 20k miles on it and i have put about 110k on. Its running like a champ, but to continue driving at such high speeds regularly i want to make sure the car is safe.
I guess im thinking i should do full suspension and maybe new brakes.
I am confident i can perform the maintenancebut im not super sure whats necessary.
Old Feb 20, 2019
GolNat's Avatar
Prelude Owner
Re: 2013 9th Gen Full Suspension for Highway.
Lift the front of the car up and check all your bushings, ball joints, tie rods wheel bearings. Unless a shock is leaking or bouncy (bounce test) then those are fine. You can Google how to test those things. If you just want to replace them for peace of mind then OEM parts are best for longevity and quality.
Old Feb 20, 2019
Seems like some pretty sound advice. Honestly i was thinking, and expecting to be told, i should get performance everything.
Old Feb 20, 2019
GolNat's Avatar
Prelude Owner
No reason to unless you want to also increase handling. I find Honda OEM suspension stuff is some of the best. I mean you just got 110K out of it so replace with OEM for another 100k.
The brakes you could upgrade to a more performance pad and rotor but they will wear more quickly and not really needed for most people. Again OEM is probably best for you because of the amount of driving you do. I usually stick with an OEM pad and premium grade rotor from a local parts store.
9THGenHighWay
General 8th & 9th Gen
Feb 20, 2019 10:20 AM
iamanthony
Jun 19, 2013 03:12 AM
Balzdpr
Jan 8, 2012 01:48 PM
Pluto
Apr 25, 2006 10:46 AM
MrWong
Mar 24, 2004 11:32 PM
