Need help with headlights!
Old Nov 17, 2017
jjnn898's Avatar
jjnn898 is an unknown quantity at this point
It is probably a simple fix, but my headlights look like this for 2009 Honda Civic LX Coupe. What can I do to fix this? It is not working on that one side. I did hit a curb pretty hard a while back, but not sure if it happened because of it. I just now noticed it.
It is also too dim, but I am going to assume that will change when I put new bulbs in (Just bought the car not too long ago), and what I use a headlight restoration kit.
- Thank You!
Old Nov 17, 2017
GolNat's Avatar
Prelude Owner
Re: Need help with headlights!
The bulb probably just burned out. Pull it out and look at it. A headlight restoration makes a difference in the light output, I highly recommend it.
Old Nov 18, 2017
do you mean the orange light? Bulb.
It seem you have an aftermarket headlight unit?
Old Nov 18, 2017
jjnn898's Avatar
Yeah, just the orange part, sorry I'm not very knowledgeable. Didn't know if it was an error beyond a bulb replacement.
Old Nov 18, 2017
jjnn898's Avatar
Will also do a headlight restoration!
Old Nov 18, 2017
Always check the cheapest/easiest thing to repair first.
