Sponsored by:
Sponsored by: CARiD
Some sort of ECU upgrade
Old May 22, 2003
Prusali's Avatar
Prusali is an unknown quantity at this point
Post Some sort of ECU upgrade
Hey everybody;
I am sorry if this has been brought up...
Someone is offering some sort of chip on ebay, for $5.95, actually it is a buy 1 get 1 free deal so you get two chips for 6 bucks. They claim up to 20hp gain. I read the information, it seems like BS to me. Tell me what you think.
+20H-POWER CHIP HONDA CIVIC 98-00-01-03 1FREE
Old May 22, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
Don't buy it!!! It's a scam and it has been brought up many, many, many times before. Try searching
Old May 22, 2003
5PEED EX's Avatar
5PEED EX is an unknown quantity at this point
:zbsflag:
Old May 22, 2003
importz2k1's Avatar
Always remember......................
If it sounds to good to be true, it usually is!
Old May 22, 2003
NeonImpact's Avatar
Forum Sponsor
just get a JET ECU upgrade...
Old May 22, 2003
KeNsHiN's Avatar
LEVA
go with jet that other **** is crap
Old May 22, 2003
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
Re: Some sort of ECU upgrade
Originally posted by Prusali
Hey everybody;
Go ahead and buy it and tell us how it performs!
Old May 22, 2003
dj pyrotechnics's Avatar
dj pyrotechnics is an unknown quantity at this point
"NO TOOLS NECESSARY!! INSTALLS/UN-INSTALLS IN 2 MINUTES!! WILL NOT VOID FACTORY WARRANTY!!
Give your Car or Truck up to 20 More HorsePower!!
100% SAFE, 100% LEGAL!!"
lease:
um i am not too sure about that!
Old May 22, 2003
Bartkat's Avatar
Is that the one that fools your ECU into thinking the intake air temp is colder? A resistor?
If they give you two, then it will think it's twice as cold.
Old May 22, 2003
konstanting's Avatar
konstanting is an unknown quantity at this point
no dont think so, otherwise it would say that.
Old May 22, 2003
Vytas's Avatar
Vytas is an unknown quantity at this point
It will mess up your engine guaranteed!( when cold air get into engine it expands. If ECU will think cold air is coming it will pump more gas than needed...you will be screwed after some time).
Do not mess with ECU upgrades, even with JetChip. I bought it , did not notice anything(opened it up , all stock, just like I send it. Maybe they reprogrammed it, but there is no way of knowing). Instead I got rough idling. BS. Searching for new ECU. Not worth the hasle.
Old May 22, 2003
Bartkat's Avatar
It do say that.
" WOULDN'T YOU LIKE A SIMPLE PLUG-IN MOD THAT SAFELY TRICKS YOUR VEHICLE'S ECU TELLING IT THAT THE AIR TEMPERATURE COMING THROUGH YOUR AIR INTAKE IS 15-20 DEGREES COOLER THAN IT ACTUALLY IS? "
This auction is for a timing advancement resistor with easy to understand instruction sheet w/helpful pics . No car knowledge is necessary, anyone could do it! All vehicles have an Electronic Control Unit (ECU)-a computer chip that electronically manages and monitors your car's performance-that is made according to government regulations. That means that your car could be going a lot faster and getting more power if you replace the ECU. that could cost up to $2,000. This mod will modify your stock ECU with a Timing Advance resistor. This resistor connects to the car's ECU by replacing the Intake Airflow Temperature (IAT) Sensor. Once the resistor is installed, the ECU will read that the air coming in through the intake is cold air; think of it as a "default" setting on the ECU. When the ECU reads this, it lean out the air/fuel mixture-in other words, it will take in MORE POWER, and then add more fuel to compensate for the extra air coming in, thus, producing more power and advancing timing 1 to 2 degrees. "
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2416241266
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
solarpunk70
Apr 12, 2016 11:43 AM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
