Sponsored by:
Sponsored by: CARiD
OEM Honda body kit... material?
Old May 8, 2003
  #61
chibOi's Avatar
chibOi is an unknown quantity at this point
the kit is made of 100% sexyness..
Old May 8, 2003
  #62
Majarvis's Avatar
Majarvis should not be trustedMajarvis should not be trustedMajarvis should not be trustedMajarvis should not be trusted
Yeah if I were you, I'd save up for the swap, it would be worth it in the long run, since your heart is set on the swap right? Then you will probably be getting it some time, and then your turbo is no good. I would just wait it out, then you would notice, and appreciate the power even more, just my thoughts
Old May 8, 2003
  #63
azure's Avatar
Yah, I'll do that. And yes, my heart is set on the swap (90% swap / 10% turbo... hehe.). Now I need to find a place that can do this kind of swap. I'm not sure there's a place like that here in Hawaii... maybe. Hopefully I find a place that knows Honda/Acura engines in and out.
Old May 8, 2003
  #64
Majarvis's Avatar
Yeah, you never know, the Honda dealer might do it, but it would cost a lot.
Old May 8, 2003
  #65
RedDragon333's Avatar
thats where im doing mine. Access to all tools, all parts and if they dont have them they can get them. I thought about the turbo since itll be a few years before the swap since warranty but if i get the K20A its going N/A. Gotta love the redline and the sounds its making at that time
Old May 8, 2003
  #66
Majarvis's Avatar
Damn!
They're letting you do it there? I wouldn't actually think a Honda dealer would let you do it!
Old May 8, 2003
  #67
Damn!
i have a sponsership with my dealership
Old May 8, 2003
  #68
Majarvis's Avatar
Oooh! Lucky you!
Old May 8, 2003
  #69
Oooh! Lucky you!
LOL thanks, it wasnt easy but its well worth the trouble it i had getting it
Old May 8, 2003
  #70
azure's Avatar
RedDragon, youuu lucky BASTARD! I don't think my dealership would do crap for me. Especially if it deals with swapping engines. But who knows. I mean, I didn't ask yet.
I'm still torn between the turbo and the swap guys. I mean, I'd like the turbo for now... to do a little killing of ricers. Hehe! I figure I can do the swap when I have piled on the mileage significantly. Do you think the engine will be available by that time? Say, within 3-4 years? I'd like to wait and save for the swap, but I just can't turn down a turbo. Haha! What do you think guys?
Old May 8, 2003
  #71
orion_squall's Avatar
yeah...I am positive there is no aero kit for sedan...at least in Canada...however, one can always use Acura 1.7EL 's aero kit...
but 1.7EL exist only in Canada.
Old May 8, 2003
  #72
azure's Avatar
What does the Aero kit for the Acura 1.7EL look like?
Old May 8, 2003
  #73
Majarvis's Avatar
Old May 8, 2003
  #74
Majarvis's Avatar
The 1.7 EL is your guys' EX Sedan, I don't know why they just don't have it as a Civic here, anyway.
Old May 8, 2003
  #75
Majarvis's Avatar
Side view.
Old May 8, 2003
  #76
azure's Avatar
Looks sweet!
Old May 8, 2003
  #77
similar to the stock OEM Civic kit, as far as the turbo goes Azure im torn just as you are. The turbo seems doable now but think about it you spend about 3k on a turbo to add about 50 HP maybe less, or you could save up the cash for the swap in the next few years. Im waiting till my warranty goes or till i finish everyting else. i was gonna go turbo but i thinkin the long run itll be wiser to save the cash and go swap. The engine should be a vailable in the next few years seeing how they are using the K series in both the Accord, rsx, SI, and CRV. I think ima wait and work on my kit and my interior then save for the swap!
Old May 8, 2003
  #78
Majarvis's Avatar
Yeah, it does look nice.
Now that would be an insteresting conversion, the 1.7 EL front and rear bumpers on a Sedan.
Old May 8, 2003
  #79
azure's Avatar
Good thinking RedDragon! I think I'm going to do the same. I'm thinking of doing the swap sometime after my warranty expires. I guess once I get my rims, maybe I'll just get the basic I/H/E setup... maybe.
Old May 8, 2003
  #80
go for the basic bolt ons then stay away from any engine mods and save save save
Old May 8, 2003
  #81
azure's Avatar
Exactly!
Old May 9, 2003
  #82
hi, guys,
I am glad my idea of 1.7EL helped you.
I think you definitely better do the engine swap...
a turbo charger can be describe as a separate unit that use the pressure of exhaust to turn a turbine. I don't know what kind of turbo charger you will get, but idially it should have it own clloing system so that when it extract the air with turbine it also cool it.
Turbo is a forced induce system, it forces more compressed air in the engine cylinder. More air mixed with gaz=bigger explosion. However, you still have 16 valves right? 4 on each cylinder, 2 let air in the cylinder and 2 let exhaust out of cylinder. If the valves number stays the same then the big amount of induced air won't necessarily go into the cylinder...so I the 50HP they claimed won't be totally true.
however, if you get an engine swap, a 2.5L for exemple, no doubt you get more power right there.
I hope my suggestion will be useful~
Old May 9, 2003
  #83
azure's Avatar
Thanks for the info orion_squall! Except the engine I'm looking at is 2.0!
Question guys... I have an automatic LX... will the swap still work for my car? (Transmission wise)
Old May 9, 2003
  #84
Majarvis's Avatar
I'm not sure about that, I know that a swap with the K20A and it's transmission is fairly straight forward if your Civic is already a manual, because the clutch pedal is already there, and all the linkages. But since you have an auto, that may pose a problem, or it may not, it's hard to say really what's involved. I'm not even sure if you can, or would want to, use the auto tranny on the K20A, I doubt that would work, but it would be a lot harder if you have an auto instead of a manual I would think.
Old May 10, 2003
  #85
azure's Avatar
I was thinking it would be hard to. If I do the swap, I'd want to swap the transmission too. I'd love to have a manual. I guess if I do swap the transmission too, I'd have to swap parts from a manual civic as well? Seems a lot more difficult. Also sounds like more $$$ would be involved. Man, the turbo is sounding really good now... hehe.
Old May 10, 2003
  #86
Majarvis's Avatar
Yeah, it would be a lot more work converting to a manual from an automatic, versus just swapping a manual for a manual, since all the linkages, and especially the clutch pedal would already be there. I'm sure it's possible to do what you want, it's just harder, and would cost more, since you would have to cut through the firewall to install the clutch pedal, then change the interior housing and buy the manual housing, like the shift boot, etc... it's just a lot more work. Having said that, you might be able to use the automatic tranny with the K20A, I'm not expert in this department, but chances are the ECU wouldn't like that too much.
Jon-Ohio
Jun 30, 2018 08:10 PM
Erndog81
Oct 31, 2015 03:01 PM
GolNat
Sep 10, 2015 08:25 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
