Sponsored by:
Sponsored by: CARiD
new cam for our car???
Old Apr 21, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
I seen this today, it doesnt make since tho,
say 01-02 civic 1.6L? is this for the si only?
it doesnt saygude cam
Old Apr 21, 2003
Ike's Avatar
Ike
Ike is an unknown quantity at this point
Gude does do a stock regrind for our car. From what I have heard their stuff really is low quality, they prolly do think our car is 1.6.
Old Apr 21, 2003
xtiszx's Avatar
Cracka
lol, ok, just something i seen, i dont want a regrind, i want a totaly new one, im thinking about going to a cnc/auto shop and see what they say
Old Apr 21, 2003
Ike's Avatar
Ike
I am damn sure no one makes a cam for our car. Personally I would turn to Crower for a regrinded cam. They'll do it right.
Old Apr 21, 2003
xtiszx's Avatar
Cracka
id rather wait then have a regrind
Old Apr 21, 2003
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
4340 steel billet connecting rods are available for your application. Stock sample and 50% deposit required. Cost is $177 per rod.
Custom pistons, pins, rings and locks run $155 per cylinder. You spec bore, compression valve sizes, etc...
Regrinds on your stock cams are available. Specs are typically 10 degrees more duration and .010 more lift. HP gains are in the 5-15 range depending on tuning. Rough idle is common if we exceed the above figures. Cost is $200 per cam. New cams will be available in about 3-4 months.
Thanks for your interest in Crower,
Crower Cams & Equipment Co Inc
3333 Main Street
Chula Vista CA 91911-5899 USA
Phone: 619-422-1191
Fax: 619-422-9067
http://www.crower.com
> Would it be possible to have any d17a2 engine parts (2001 honda civic
> ex)made? Or are there any available? If you can custom make parts,
> how do I go about ordering them for this engine?
Old Apr 21, 2003
Da2K1's Avatar
Da2K1 is an unknown quantity at this point
I've heard the Gude cams work GREAT from racing shops. Talk to anyone here:
http://www.dynospotracing.com/index.htm
(they are not dealers for Gude)
I'm gonna get a set of these cams in a couple of weeks
Old Apr 21, 2003
RedDragon333's Avatar
I wouldnt go through GUDE, lot of bad things happen they did a project on a 7thgen a while back and it was nothing but trouble. IM waiting for Crower
Old Apr 21, 2003
Da2K1's Avatar
i believe Black99Vtec has a bunch of Gude stuff (maybe others, as well). It's possible the shop that did the install messed it up. I've heard stories of cams being incorrectly installed that have caused motors to run bad. I remember reading a story on this site of someone who got the head package & traded in his civic in the end, as it ran bad. I wonder if he knew the guy that did the work? I pay for my work to be done (if i can't use a DIY) from someone i trust, just so stuff like that will not happen. We'll be doing a visual inspection before the install & a dyno to ensure correct installation. I don't mind using my civic as a test mule. If the motor gets messed up, i'll just get an RX- 8
Old Apr 21, 2003
Marc's Avatar
Marc is an unknown quantity at this point
Regrinds are not great, but if you get the hardfacing option you won't be limited.
from the crower site:
Hardfacing - Welding up stock lobes (if VTEC, mid only) to allow unlimited spec while maintaining stock base circle. Cost $40 per lobe plus $100 per cam for the grinding. VTEC weld is only on mid lobe (8 lobes + grinding = $520 total). You supply stock cores. VTEC specs listed above are available on hardfaced cores. Full drag race, road race, turbo or nitrous. No wear or compatibility issues.
The only question I have is the cam solution treated to get the proper hardness.
Old Apr 21, 2003
Bartkat's Avatar
I don't know if the problem the guy had with the Gude head and cam package was ever resolved. As I remember there were problems with using the stock valve springs, etc. There seemed to be much miscommuications with Gude. Id didn't sound like the kind of deal one would want to go through. It certainly wasn't a bolt it up and go situation.
Old Apr 22, 2003
Its funny cuz GUDE swore up and down it was a simple asa sending it getting it done and bolting the "new head" on. That was a messed up ordeal i remember that one
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
Tybonater
Apr 24, 2015 07:03 PM
Myredjonda
Apr 14, 2015 07:00 PM
thesushiboy
Apr 12, 2015 07:40 PM
