Sponsored by:
Sponsored by: CARiD
Weighted Shift Knob
Old Apr 14, 2003
CarbonFly's Avatar
Weighted Shift ****
Does anyone have one? I hear that they help in shifting so you can truly throw the stick in each shift without mis-shifting.
Anyone got any ideas about this?
Old Apr 14, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Actually I hear they're not good for your tranny... because of the weight, it pushes the lever farther than it needs to go into the gate and stays there, so it forces the gears together and you can cause some damage to them.
Old Apr 14, 2003
Bartkat's Avatar
I prefer something like a eight ball or a beer tap handle.
Old Apr 15, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
boilermaker: umm... I don't think that's the case with 7th gens ...
well ... a heavier **** will make your shifting easier ... cuz more inertia. I have a heavy razo **** ... weighs more than a pool table ball. Anyway, I think the heaviest one they have is like 400 grams ...
Old Apr 15, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
I bought the RSX upgrade shift **** and it helped on shifting (easier to shift) I hope that helped!
Old Apr 15, 2003
WeSSoN's Avatar
WeSSoN is an unknown quantity at this point
i have this greddy weighted **** and it makes a helluva difference!!!
Old Apr 15, 2003
tdiddy's Avatar
tdiddy is an unknown quantity at this point
I have a tenzo shift ****, came with two different weights i dont see to much of a difference, but i dont believe that it will damage my transmission. I dont need a shift **** to help me with that.
Old Apr 15, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
It probably won't damage your transmission any more than you will from the type of driving you do. Since the gears are always constantly meshed, I don't see how they can be pushed closer together, though I suppose it could push the gear selector fork closer to the gear which wouldn't cause any damage because they're made to be meshed at any distance. The only damage I can see coming out of it is if you try to "throw" it into gear, and it doesn't go in and you do some grinding when you let the clutch out. Hope this helps
-Mark
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Jrosa
Sep 14, 2015 08:24 PM
