Sponsored by:
Sponsored by: CARiD
M3 Mirror Answers
Old Apr 8, 2003
Htowncivic's Avatar
Htowncivic is an unknown quantity at this point
M3 Mirror Answers
Ok...I've done a lot of searching and pming, does anyone know exactly where you connect the LED wires of an M3 mirror?
Old Apr 8, 2003
kempster's Avatar
kempster will become famous soon enoughkempster will become famous soon enough
you connect them with ur blinkers. If i remember correctly the wires were way to short so i had them changed
Old Apr 9, 2003
Htowncivic's Avatar
Are those blinker wires located right behind the headlight, what color are th eones you're supposed to T-tap?
Old Apr 9, 2003
prototype's Avatar
x-factor
you have to add more wire if you want the connected to the headlight blinker, i had enough wire b/c i connecter it directly to the blinker module in the steering column.
Old Apr 9, 2003
sovereign82's Avatar
sovereign82 is an unknown quantity at this point
I can't figure out which wires to hook up for the Power Portion of the mirrors....HALP!
We need some color codes up in here.
Old Apr 9, 2003
prototype's Avatar
x-factor
i think there a red and white....to test connect it to the battery it only lights up if they are connected the right way
Old Apr 9, 2003
That can't be right because if I remember correctly, there are no red or white wires...and the left and right side hae completely different colors than the other side.
Old Apr 9, 2003
blazed870's Avatar
blazed870 is on a distinguished road
I don't know if this helps but here it is.....
"blazed870 wrote on 03-18-2003 10:48 PM:
I saw your post about the m3 mirrors. When you said the cluster did you mean the gauge cluster, and if so are the wires on the green plug or blue plug. If not, what cluster are you talking about? I apreciate the help.”
Blue harness.
Green Red and Green Yellow. I forgot which is left or right, you'll need to use a light tester.
Old Apr 9, 2003
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
use the wiring that under by your fuse panal. I used the rear blinker wires that were down there. Just go to the back of your car pull back the grey matt, see what colors go to the blinkers and find them int he clump of wires that down under that fuze pull off cover. I can get the exact colors when i go home.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
Islesfan
Sep 29, 2015 03:42 AM
carid
Sep 28, 2015 10:13 AM
Jrosa
Sep 14, 2015 08:24 PM
