Sponsored by:
Sponsored by: CARiD
EGT Gauge?
Old Apr 3, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
EGT Gauge?
Is there an actual need for an EGT (Exhaust Gas Temp) gauge? I was under the impression that an EGT is mainly used to indirectly tell you if you you are running lean or rich based on the temp. But if I have an Air:Fuel gauge, is an EGT gauge necessary? I ask because I was looking at some cars around the internet and a fair amount have EGT gauges. Does it serve another purpose?
Old Apr 3, 2003
Grey's Avatar
DIY King
It's pretty much a relic. It's good for tuning the air/fuel ratio at wide open throttle. Nothing more. Same for the air/fuel guage. Even the good ones (like Autometer) aren't really accurate at anything but wide open throttle. You need a wideband O2 sensor to get the best reading of your air/fuel ratio. That's what you tune the air/fuel ratio with.
The necessary guages for say a turbo would be oil temp (to make sure it doesn't get too high and cake up the inside of the turbo and get past seals and so on), boost guages (needed to see what boost you're running, duh!), and air/fuel ratio with a wideband O2 sensor. The ones like the autometer are okay for riding with I guess, but should never be used to tune.
Old Apr 3, 2003
Boosted2k2's Avatar
So it's not something to actually buy then? They just use it on a dyno to tune the fuel map? Unless you get like the AEM EMS. It has an optional EGT sensor that simultaneously tunes the Air/Fuel Ratio.
Thanks
Old Apr 3, 2003
prototype's Avatar
x-factor
i used an egt on my eclipse. i had an upgraded turbo and the boost was aboyt 12 lbs 3" exhaust cams the whole 9 id always look at the egt b4 i raised the boost up or i hit my sneaky pete if i was running too hot id back off
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
