Sponsored by:
Sponsored by: CARiD
Hyper Ground wires
Old Feb 17, 2003
player's Avatar
Hyper Ground wires
i have seen this around, they look nice, but what do they do? what is there function, what gains do they cause ...... were are the installed, please explain.
Old Feb 17, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
cars work from negaitve to posative. These grouind wires improve
the connection to the chassis giving a better connection and a less
restrictive flow of current improving all electrical aspects of
the car. Better throttle response, better performing alternator,
A/C, etc. etc.
Old Feb 17, 2003
Sweetpants's Avatar
Sweetpants is an unknown quantity at this point
and they actually do add horsepower...its been proven
Old Feb 17, 2003
blazed870's Avatar
blazed870 is on a distinguished road
whats a good price and place to purchase the ground wires? Is it easy to install?
Old Feb 17, 2003
skipbarber's Avatar
i dont even think you have to buy a kit, in my opinion id just use thicker gauge wires and polished contacts. people who buy kits just like them for different color wires. i think aerospeed has a universal ground kit.
Old Feb 17, 2003
blouisgod's Avatar
Life Begins > 6800rpms
i have them and they work to a certain degree. the reason i know is because running more than 1 accessory at once seriously causes you to lose power. example, if i have the fan on and turn on the rear defroster, forget it, the fan is worthless. it definately lowers resistence but im not to sure about increasing power. btw, i have arospeed wires tagged to the alternator, trans block, head and ignition ground. ur supposed to have one on the intake but ours is plastic
Old Feb 17, 2003
kjgracing's Avatar
There are 4 bolts on the throttle body. That is supposed to be the intake attatchment.
I have Areospeed. It was about 40 bucks off of Ebay. You could make your own wires using 8 gauge wire with gold connects.
Very easy to install.
Old Feb 17, 2003
spencerkam's Avatar
spencerkam is an unknown quantity at this point
ImportTuner tested out some a grounding kit on some car. I don't remember which car off the top of my head. But, I do remember the car gaining 5HP on the dyno
Old Feb 17, 2003
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I was reding an install on the Hyper Ground Wires, tsome of the cars made good hp and an s2000 made 3 hp, they said they had the best results after putting the wires on the ignition coils of the s2000. What do you guys think of that idea?
Old Feb 17, 2003
XTREME2K2CIVIC's Avatar
Reppin Stage 7
Quote
[hr]Originally posted by: SkipBarber
i dont even think you have to buy a kit, in my opinion id just use thicker gauge wires and polished contacts. people who buy kits just like them for different color wires. i think aerospeed has a universal ground kit.[hr]
I used some extra ground wire from my system and it worked fine...
Make your own.
Old Feb 17, 2003
blouisgod's Avatar
the main part of the system is the arospeed negative battery terminal post; it builds on the stock setup giving you 2 ground points rather than 1. i could ground another cable to the TB but i dont think that'll do anything. grounding the coils is what you do when you touch the head and the ignition ground, which is right near the head. if you can score one for 40 bucks then grab one. one downfall is the amount of wires you have in your engine bay.
Old Feb 18, 2003
nightkids1's Avatar
Initial D!!!!
yeah i was thinking about getting this, probly get more hp from this then my intake
Old Feb 18, 2003
Grey's Avatar
DIY King
Wait, what's the point of putting multiple wires from the negative battery terminal to the chassis? Won't the electricity take the path of least resistence. Oh wait, the flow goes the other way. Yeah, you're just providing it alternate paths of entry, so based on where something else is grounded it'll find the shortest path to the battery. Nevermind. I get it. I'll probably do this too.
Old Feb 18, 2003
rino's Avatar
rino is an unknown quantity at this point
so is aerospeed the only one who makes a kit, and does this kit include everything you need. I am thinking about doing this. Could someone maybe give a link to the aerospeed wires.
Old Feb 18, 2003
dragoon's Avatar
what my friend sent me: taken from the p5 forums
This is probally a pretty easy one for any body with a set of wire crimppers, some ring clips, and about 7 feet of 4 gauge wire. The concept is simple, you daisy chain the grounds from one side of your engine bay to the other side. Using the first ground as your chassis( right side of car), second to your throttle body, next down to your engine block, split the next wire to your tranny and then next to your battery and daisy chain another wire off battery to another chassis ground of your choice on left side of car.
Old Feb 18, 2003
player's Avatar
We need either a detailed DIY, or a kit that tells were everything goes
Old Feb 19, 2003
dragoon's Avatar
Use a multimeter or something to check for good grounds.
1. Chassis right to throttle body.
2. Throttle body to engine block.
3. Engine block to transmission and battery negative
4. Battery negative to chassis left.
It's fairly simple to do, but the actual kits use better wire than even audio stuff. I'm not sure about arospeed's kits, though
If you don't know where to properly ground things, chances are you shouldn't be messing with this anyway.
Old Feb 19, 2003
rino's Avatar
ok so you are saying the kits actually have better wire than if you went out and bought the wire yourself. Are there any other kits than aerospeed and can anyone give me a link to them. Thanks
Old Jul 9, 2003
iceman's Avatar
--< GripSpeed Member >--
Just curious..has anyone actually bought and installed the hyperground or the areospeed grounding kit...if so...whats ur feedback on them...
hondadriver95
Jul 13, 2015 09:43 PM
Jul 12, 2015 11:54 AM
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
