Sponsored by:
Sponsored by: CARiD
o2 sim on diabloautosports
Old Jan 9, 2003
tAkTicS's Avatar
tAkTicS is an unknown quantity at this point
hey im going to order this tonite... but i just want to make sure that its the right part.
ECG Electronics O2 simulator - Honda/Acura OBD II $47.99
its that one correct?
diablo site
Old Jan 9, 2003
tAkTicS's Avatar
o ya and if anyone has found it for cheaper... leave the site
Old Jan 9, 2003
IllusiveImports's Avatar
IllusiveImports is an unknown quantity at this point
don't buy it. we just found out something very interesting. if you have an o2 sim ya your cel is off, but 2 things one your ecu still reads the o2 levels and knows the light sohuld be turning on you are just bypassing it hich means you still have the same effect which is nothing in a lx and dx but in the hx and ex v-tec is disabled, just that the annoying oragne light isn't on. the second thing is that for emissions they are trained to look for a sim and it is illegal to use. and whats the point in getting one since your car will still put out the same emmisions which means you will still fail the test.
Old Jan 9, 2003
tAkTicS's Avatar
where did you hear that?
i thought i read somewhere that it will correct something with the fuel MAP, and the car will run better because of the o2 sim.
btw i have a LX so the vtec thing doesnt affect me.
and i thought that the whole point of using an o2 sim was to get the CEL to turn off so that you would know if something really did happen to your engine to get the CEL to turn on again.
Old Jan 10, 2003
tAkTicS's Avatar
as for emmisions, i thought that i could still pass the pollutant level part but not the visual because of the replaced cat because its not just the cat that makes our cars ULEV. so i dont see how the o2 sim would affect that.
Old Jan 10, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I have the o2 sim, it has nothing to do with VTEC!! It hooks up to the TPS and the RPM sensors, and depending on where the throttle is and RPM's are, it gives the ECU a reading for correct emissions even though the emissions arent correct, it tricks the computer into getting the right fuel maps depending on how hard you are getting on the throttle. I was quite happy with the o2 sim, and my car performed much better with the downpipe and 02 sim than it did with the stock cat. THe o2 sim has been talked about many times here and i posted a DIY somehwere, if you search you should find it.
Old Jan 10, 2003
zetaR's Avatar
zetaR is an unknown quantity at this point
Quote
[hr]Originally posted by: IDQcivic
I have the o2 sim, it has nothing to do with VTEC!! It hooks up to the TPS and the RPM sensors, and depending on where the throttle is and RPM's are, it gives the ECU a reading for correct emissions even though the emissions arent correct, it tricks the computer into getting the right fuel maps depending on how hard you are getting on the throttle. I was quite happy with the o2 sim, and my car performed much better with the downpipe and 02 sim than it did with the stock cat. THe o2 sim has been talked about many times here and i posted a DIY somehwere, if you search you should find it.[hr]
Agreed.
Old Jan 10, 2003
actualy it does do something to y-tec honda made the ecu a failsafe system. if the 02 readings are wrong then it switches off v-tec so it won't hurt your car mroe just call a honda tech and ask them its even in the maintence guide you can buy at the dealerships for like 90 bucks. about the emissions you will not pass, there are different parameters set for ech motor. so being that our cars are ulev the emissions requirement is a lot lower but that also depends on where you live since some states don't require emissions at all.
Old Jan 11, 2003
tAkTicS's Avatar
ok but i had the right part info... im ordering the right part right?
Old Jan 11, 2003
IronFist's Avatar
Quote
[hr]Originally posted by: IllusiveImports
its even in the maintence guide you can buy at the dealerships for like 90 bucks. [hr]
They sell the maintence guide for $90?! Holy crap.
IronFist
Old Jan 11, 2003
ya 90 bucks is a ot i think its 80 now but my friends and i got ours off ebay for like 45 since thats about how much the shops get them for. it has helped me out with a lot of things
Old Jan 11, 2003
IDQcivic's Avatar
Quote
actualy it does do something to y-tec honda made the ecu a failsafe system. if the 02 readings are wrong then it switches off v-tec so it won't hurt your car mroe just call a honda tech and ask them its even in the maintence guide you can buy at the dealerships for like 90 bucks. about the emissions you will not pass, there are different parameters set for ech motor. so being that our cars are ulev the emissions requirement is a lot lower but that also depends on where you live since some states don't require emissions at all.[hr]
what is y-tec? I think you mean VTEC... anyways... the whole point of the o2 sim is to give the ECU readings that were the same as if you had a cat... That's why it hooks up to your RPM and TPS sensors, because it knows what reading it should get depending on how hard you get on the gas. If the ECU is getting emissions readings it still think it has a cat because that is what the o2 sim does. Except the emissions just leave the exhaust instead of being converted with the catalytic converter. I can still feel the VTEC kick in with the o2 sim hooked up...
jonny9508
Sep 4, 2003 04:00 AM
HYPR DRV
Aug 2, 2003 10:05 AM
HYPR DRV
Jul 20, 2003 05:31 PM
cwick187
May 22, 2003 09:29 PM
