Sponsored by:
Sponsored by: CARiD
AEM Fuel Rail?
Old Dec 20, 2002
Rollin0n18s
Guest
Posts: n/a
AEM Fuel Rail?
I noticed that AEM has come out with a high flow fuel rail and I was wondering if there is a big difference in power, when this is installed and would i be able to put this on an automatic
Old Dec 20, 2002
VTECTypeR's Avatar
you can put it on a automatic but for gains not sure if its gonna be big but u probably need it for a turbo or somethin
Old Dec 20, 2002
KeNsHiN's Avatar
LEVA
yeah i think that it more effective if you are running something like turbo
Old Dec 20, 2002
Hwoody77's Avatar
Hwoody77 can only hope to improve
Where did you find this?
Old Dec 20, 2002
2001civ's Avatar
2001civ is an unknown quantity at this point
It will give you one MAYBE two hp if you are lucky. the purpose of a fuel rail is mainly to handle more fuel pressure, higher fuel pressure need for things like a turbo. but just a new fuel rail isn't worth the money. but you can put in an auto or stick
Old Dec 21, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Well, it is not really going to do crap-o-la for a turbo either. A fuel rail is most effective when running a higher pressure pump and bigger injectors.
Old Dec 21, 2002
RedDragon333's Avatar
Quote
[hr]Originally posted by: bobbyd
Well, it is not really going to do crap-o-la for a turbo either. A fuel rail is most effective when running a higher pressure pump and bigger injectors.[hr]
Exactamundo (for all you Demolition Man fans)
Old Dec 21, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
So what if I upgrade the fuel rail and get bigger injectors but stick with the same fuel pump and still run NA.. would that help anything at all?
Old Dec 21, 2002
bobbyd's Avatar
Quote
[hr]Originally posted by: IDQcivic
So what if I upgrade the fuel rail and get bigger injectors but stick with the same fuel pump and still run NA.. would that help anything at all?[hr]
It will help a little but you are still going to be pumping the same psi through. I guess it would be like an exhaust. Biger pipes will help it flow better.
carid
Nov 7, 2015 01:46 AM
Damn HeadGasket
Aug 23, 2015 05:27 PM
GritzNGravy
Aug 19, 2015 03:03 AM
martinsmartin
Aug 15, 2015 07:34 PM
Green02civic
Jul 27, 2015 10:48 PM
