Sponsored by:
Sponsored by: CARiD
Inner Fender
Old Dec 9, 2002
player's Avatar
Inner Fender
Ok i got 2 small blue bulbs t put into the parking light (that middle circle on the headlight). in the handbook it says to take out a small pop in screw by pulliumg it out, then remove the inner fender and install the light, first i pulled the damn screw and the thing poped out but brock ( it is plastic), then i cant quite get how to remove the fender? do i just pull it out, and what part?
is there an easuer way to do this anyways?
thanks
Old Dec 9, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
All you need to do is to remove all the screws that hold the inner fender on and then just bend it down out of the way and you should be able to get the bulbs no problem, thats all I did when I put mine in.
Good Luck
Old Dec 9, 2002
Diemos's Avatar
Diemos is an unknown quantity at this point
Quote
[hr]Originally posted by: player
thanks[hr]
your sig is huge, fix it.
Old Dec 9, 2002
CarbonFly's Avatar
Quote
[hr]Originally posted by: Diemos
your sig is huge, fix it.[hr]
His sig is always huge........live with it.'
Old Dec 9, 2002
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
I broke a couple of my clips too, not to worry. But like he said, just pull the clips out, fold down the plastic trunk lining and you'll be able to see where the bulbs are plugged in at. Quite simple really ...
Old Dec 9, 2002
allniter's Avatar
allniter is an unknown quantity at this point
There is only one screw and one clip that you need to remove to bend the wheel well back to access that lights.
Remove the screw that holds the bumper on, pop the side of the bumper out (this makes it easier to bend back the wheel well). Then remove the clip closest to where you are trying to open (should be right above the wheel) and then just bend it back.
Old Dec 9, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
You should be able to pop two or three clips out and bend the plastic part down towards the tire enough to fit your hand in there. Just be careful with the clips because they do break pretty easy. And if your car is lowered at all, you might have to jack the front end up a bit in order to fit your hand in between the tire and the fender.
Old Dec 9, 2002
player's Avatar
ok DONE, i had to break both clips of, but whatever they arnt important, are they?, anyways, what made it so hard the first time was all the dirt and snow stuck in there, so i car washed teh car and the job got done no problem, thanks ghuys for your help
Old Dec 9, 2002
AEMcivic's Avatar
WHAT?!! You broke the clips?! Aw man, now your engine's gonna fall out!
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Sep 25, 2015 12:12 AM
emiixo
Exterior
Sep 22, 2015 03:53 AM
rnaodm
Sep 21, 2015 12:42 PM
beeemerdude
Jul 23, 2015 03:53 PM
