Sponsored by:
Sponsored by: CARiD
i know another turbo question
Old Nov 22, 2002
BIRDMAN's Avatar
BIRDMAN is an unknown quantity at this point
will my lx handle say 7psi? also does anyone know where i can get a custom intake and exhaust manifold?
thanks
Old Nov 22, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
7psi would probably be the threshold. That's the point where you should start to upgrade internals and fuel management. Just to be safe, you should probably stick at or under 5psi until you upgrade.
You can get custom exhaust manifolds for around 400 or 500, just do a search and I'm sure you'll find lots of good info.
I don't know much about the intake manifolds, but I'm sure you can find someone to make or modify one for the right price.
Old Nov 22, 2002
Barney's Avatar
Barney should not be trustedBarney should not be trustedBarney should not be trusted
Yes, your motor will handle 7 fine. 9 at the max.
For a custom intake manifold you will have to do it your self or find a good machine shop to do it for you.
The exhaust manifold for a turbo is either going to have to be custom or go to turbo-performance.com, also hks might make one in the future and I think a couple of other companies on here have custom made them.
Search a little. There is a ton of threads with the answers
Later
Old Nov 22, 2002
BIRDMAN's Avatar
thanks guys i'll do some searching and see what i come up with
-HondaFTW-
Aug 30, 2015 10:38 AM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
bhollie
Aug 12, 2015 09:58 PM
justcruzin125
Aug 11, 2015 09:09 PM
