Sponsored by:
Sponsored by: CARiD
bottled balls
Old Nov 15, 2002
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
bottled *****
I've got a begginer question for you all. What is the difference between liquid nitrosoxide and dry nitrosoxide? I see both for sell but which one is better? Also is a fogger system better theat a stream? Just trying to get the info befor I blow my self up. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 15, 2002
BigHippo22's Avatar
BigHippo22 is an unknown quantity at this point
search for the nitrous post...it explains some stuff
Old Nov 15, 2002
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
Easiest way to answer is to tell you to use the search button. There must be like a hundred threads about nitrous. Im assuming from your question that you mean "wet" and "dry" kits? That is referring to the method the nitrous is used. Our cars require a wet system because we have no fuel return line, so we need to tap into our fuel system and spray additional fuel along with the nitrous. If you see pictures of a wet system, there is one jet nozzle with 2 couplings and lines running into it, one is your fuel and the other is your nitrous. Before you go off and blow yourself up like you say, definitely do more research. Adding things like this to your engine is not as easy as ordering your hamburgers with or without cheese.
Hopefully no one is going to flame on this one, and maybe add their own 2 cents?
jackoncruzpr
Sep 29, 2015 07:59 PM
Sep 27, 2015 11:33 AM
Joecrowe
Sep 24, 2015 09:12 AM
bashea
Sep 15, 2015 04:59 AM
