Sponsored by:
Sponsored by: CARiD
aem fuel rail?
Old Oct 27, 2002
nongv's Avatar
nongv is an unknown quantity at this point
aem fuel rail?
when will the aem fuel rail be out? it has been in development for the longest.
Old Oct 28, 2002
greg2k1's Avatar
greg2k1 is an unknown quantity at this point
Just curious, do you think you need a bigger fuel rail?
Old Oct 28, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
i was wondering if this would work:
1. get an afc
2. get larger injectors
3. lean out the car to trick ecu into dumping more fuel to compensate.
would it work?
Old Oct 28, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
Quote
[hr]i was wondering if this would work:
1. get an afc
would it work?[hr]
see, ive been thinking about things like this also...
i cant seem to figure out why the returnless fuel system is so hard to work with......in theory if you had a bigger pump, and bigger injectors, and some means of controlling the fuel flow, maybe somekind of piggyback computer, then what would keep you from being able to make big HP?
mark
Old Oct 28, 2002
atomicblue's Avatar
atomicblue is an unknown quantity at this point
what do u need a fuel rail for?
Old Oct 28, 2002
Mitch's Avatar
Mitch is an unknown quantity at this point
starving larger injectors shortens there life.
Old Oct 28, 2002
Bartkat's Avatar
Quote
[hr]Originally posted by: mwwhonda
Quote
1. get an afc
would it work?[hr]
mark[hr]
You probably could if you added other mods so the engine could take advantage of the better fuel flow. Heads, cam, pistons, etc, etc. Then you might need stronger internals to be able to handle the added power, plus an improved drive train to put it to the ground.
Old Oct 28, 2002
ilv4nos's Avatar
ilv4nos is an unknown quantity at this point
unless you have a turbo or have interior work done you dont need a fuel rail....fuel rail = waste of $$$
My Civic
Old Oct 28, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
not necessarily...
if you install the AEM fuel rail, accompanied by upgrade injectors, or blue-printed injectors at the least, and maybe even a better fuel pump, i believe that this would compliment the basic I/H/E quite nicely. however, it is true that you will burn MORE FUEL this way, unlike OEM specs. but you will see an increase in HP, but it may not be too significant for the cost.
Old Nov 8, 2002
xblkcivicx's Avatar
xblkcivicx is an unknown quantity at this point
The fuel rail would be nice if you want to run n2o, it has a nitrous port...
Old Nov 8, 2002
AceKicker's Avatar
AceKicker is an unknown quantity at this point
well back to the original question YES it is out for our cars.
Old Nov 9, 2002
iamboo's Avatar
Retired - SoCal FI Mod
i thought fuel rails were universal... [IMG]i/expressions/face-icon-small-confused.gif[/IMG] oh well..
Old Nov 9, 2002
xblkcivicx's Avatar
They are not universal due to the mounting studs, they are in different locations on different blocks.
130.00 from andrewsimportperformance.com Link for the lazy...
carid
Nov 7, 2015 01:46 AM
Damn HeadGasket
Aug 23, 2015 05:27 PM
GritzNGravy
Aug 19, 2015 03:03 AM
martinsmartin
Aug 15, 2015 07:34 PM
Green02civic
Jul 27, 2015 10:48 PM
