Sponsored by:
Sponsored by: CARiD
What's an A/F Gauge for?
Old Oct 25, 2002
IronFist's Avatar
I know it measures the mixture of Air to Fuel. Thanks.
But how does it work? Does the light go back and forth like in the example photo autometer has? Or does it just stay in one place based on your mixture. What warrants needing to install one? Is it ever like "oh crap thanks to my A/F gauge I knew my mixture was off and I saved my engine!" or is it only necessary if you have Turbo.
Thanks guys,
IronFist
Old Oct 25, 2002
Hwoody77's Avatar
Hwoody77 can only hope to improve
Well it depends on what kind of car you have, but most the the times it goes up and down. When you're just cruising it goes down, but when you gas the car it goes back up.
It isn't necessary on a stock NA Civic, but it's a good investment if you add a turbo, or nitrous, or go into some heavy NAing. But it dosen't hurt to have.
Old Oct 25, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
if you're cruising at say half throttle, or idling, the meter will always be jumping back and forth. the reason is that the oxygen sensor in the exhaust senses how much oxygen is in the exhaust and therefore infers what the mixture is doing. if the mixture is too rich, it will lean it out, and vice versa. since conditions are always changing, a set number for the mixture can never be reached, so it bounces back and forth. when coasting at completely closed throttle, there is no mixture so the gauge (mine at least) shuts off till you give it gas or go back to idling. the one other time it is static is if you're at wide open throttle, at which point the mixture goes full rich and the gauge reads accordingly.
as said before, it's not real necessary on N/A cars, just looks cool, but can be useful in FI applications.
Old Oct 25, 2002
nongv's Avatar
nongv is an unknown quantity at this point
hey Hwoody77 you got a 15.8. what do you have in your car?
Old Oct 25, 2002
GhettoCivic's Avatar
GhettoCivic is an unknown quantity at this point
- Was it hard to install? How much did it cost?
Old Oct 26, 2002
prototype's Avatar
x-factor
its to measure the mixture of fuel and air as it combusts
Old Oct 26, 2002
Hwoody77's Avatar
That was months ago, my car was stock.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
