Sponsored by:
Sponsored by: CARiD
Variable back pressure exhaust?
Old Oct 25, 2002
IronFist's Avatar
In the book "Civic Duty" there's a pic of an exhaust that has a flap cover on it with holes in it to change the amount of back pressure as you change how much you press the gas. Has anyone ever seen one of these before? Is it legit or a gimmick?
IronFist
Old Oct 25, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I think arospeed makes something like that, they call it an exhaust control system...check it out!
Old Oct 25, 2002
IronFist's Avatar
That appears to be more for sound control than performance and backpressure, but similiar idea I guess.
The valve I was talking about opens and closes on its own I assume. I don't think it's driver controlled like the one above.
Probably just a gimmick, tho, or else more people would use them I assume [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
IronFist
Old Oct 26, 2002
4bangin's Avatar
there is an exhaust, or a muffler anyway, that i saw in an import mag that has rings or large washers that can be removed or added to change backpressure and sound, i believe. I dont know if that is what u r talking about or what. i thought it was kinda interesting tho.
Old Oct 26, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Domestics call it a butt-plug and I do too.
Old Oct 29, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
nissan uses a muffler like that...
Quote
[hr] Variable-Capacity Muffler
Delivers wide-open power-boosting exhaust flow without blowing Maxima's quiet, stealthy cover. A special valve stays closed when revs are low (e.g., when you're sitting at a stop light), and opens when engine speeds rise to allow for maximum flow and full-tilt horsepower.
[hr]
mark
Old Oct 31, 2002
Grey's Avatar
DIY King
Yeah, the Aerospeed one is only for muffling since it's not dynamic. One that changes the backpressure of the exhaust system with the engine rpm's is actually good for performance. I know that one other sport compact had a variable exhaust system, forget which one though. Toyota Corolla maybe? Anyway, the real deal is good for performance. If I could I would swap in one from another car. An aftermarket one that is... I'll have to do some research...
Old Oct 31, 2002
SMX's Avatar
SMX
SMX is on a distinguished road
An engine is an air pump. An air pump makes more power by moving more air in and out of it. Moving air out of an engine means having an exhaust that flows well and maintains exhaust gas velocity at the valve. Anything that restricts that flow (backpressure) reduces power. What you want to control is exhaust gas velocity. Under some conditions (low rpm), a smaller exhaust header can maintain velocity better than a larger header and make more power at that particular RPM. It ain't backpressure, it's properly tuned exhaust at that RPM that makes the difference. The notion that backpressure is good at low RPM is BS.
Old Oct 31, 2002
Grey's Avatar
DIY King
Yeah, exhaust gas velocity. At lower rpm's you want the exhaust system to be of a smaller diameter so that the exhaust gases don't get a chance to cool down and therefore slow down. I know about headers and the concept of shockwave tuning, but these variable exhaust systems only work within the muffler. I'm not exactly sure how they increase performance (backpressure was the wrong term to use; lord knows I've heard it way too often). I think I saw a commercial for a car with that kind of exhaust system and they showed a cut away. It looked like a valve controlled how much piping the exhaust gases went through within the muffler. Seems weird though 'cause I think this would only have an effect on reducing noise from the exhaust.
I guess a true variable exhaust system would have two pipes leading from the header on back with different diameters. The one with the smaller diameter would be open at lower rpm's and the one with the larger diameter would be open at higher rpm's. Seems kinda bulky though...
Old Nov 1, 2002
SMX's Avatar
SMX
I think Yamaha had a variable exhaust a few years ago on their sportbikes. Can't remember what it was called but as I recall it was designed to maximize exhaust gas velocity at low rpms while opening up to support WOT rpms as well. Kinda like VTEC for your headers.
Old Nov 1, 2002
SMX's Avatar
SMX
Now I remember - EXUP (i think)
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
dinsum
May 28, 2015 09:30 PM
Supramk3
May 11, 2015 07:55 PM
crowtoo
May 11, 2015 06:50 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
