Sponsored by:
Sponsored by: CARiD
Is there a difference between...
Old Oct 17, 2002
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
Lower upper strut
rear upper strut
and rear lower strut?
There was a post about this today I think but da*n I can't find it
anyways
When buying these 3 does it matter what brand it is? like skunk2, Dc.. etc?
I know it matters when you buy the upper front stut bar because you need one that fits with a Intake
I am going to buy these 3 things but I don't want to spend too much. I just need a product that gets the job done. And was just wondering are brand names any different then something that is not brand name?
Old Oct 17, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Ok... sorry, but I've been waiting to use that. I'll answer it. The DC ones are for looks. They're hinged and have circles drilled in them to reduce the weight. Unfortunately, it also makes them weak. Get the Neuspeed front bar... Solid construction, I put it in my car last night, 15 minutes. For the lower, Skunk 2 is a good one, I almost bought it, but I've decided I'm going to get the Progress Anti Sway bar (tie and sway bar combo). If you get the Skunk2, there is an option for a Hard anodized coating, which is teflon jacketed, so it'll be pretty scratch resistant. It costs no more than normal. When you buy the good ones, they won't just be for looks. If you're going to push the car hard, then get the good bars, cuz the $30 ebay ones probably aren't going to work too well. But if you just want the look, then the cheapies are fine. Remember that fewer hinges and pieces that make up the bar means that it's stiffer, so look for welded joints or single piece construction, and where applicable, multi-point attachments. As far as the upper rear tie... I think the strut towers are in the floor of the trunk. SO they have the trunk floorpan supporting them, I'm not sure if it would do anything to put a bar between the upper rears.
Old Oct 17, 2002
MSoft's Avatar
MSoft is an unknown quantity at this point
No namers are known to snap under pressure if you're unlucky, especially on a lowered car not on aftermarket springs, and definitely on a track. You do pay for quality for most brand names. DC is really the only one that's over-priced. Neuspeeds, Tenzos, Skunk2 are all good brands.
Old Oct 17, 2002
pbfoot's Avatar
read these...this from the neuspeed catalog.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] FL_tie.jpg (18 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] FU_strut.jpg (55 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] sway.jpg (24 Kb)
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] UandL_TB.jpg (30 Kb)
Old Oct 17, 2002
Quote
[hr]Originally posted by: MSoft
No namers are known to snap under pressure if you're unlucky, especially on a lowered car not on aftermarket springs, and definitely on a track. You do pay for quality for most brand names. DC is really the only one that's over-priced. Neuspeeds, Tenzos, Skunk2 are all good brands.[hr]
That is all I wanted to know[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
I thought all of them were the same just different names
JetsterDajet
52
May 8, 2016 12:11 AM
General DIY
Sep 25, 2015 08:02 PM
speedlever
Sep 24, 2015 07:18 PM
TheRiddicles
Sep 21, 2015 01:28 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
