Sponsored by:
Sponsored by: CARiD
Thottle body extender? adds 20 hp ???
Old Oct 13, 2002
OsOBooSTeD's Avatar
OsOBaNNeD
ok heres the deal i was looking on SummitRacing.com and theres an extender for our throttle bodys ? it adds 20 hp ? i dunno take a look...ALL THE WAY ON THE BOTTOM...
ITS 89 BUCKS? IS THIS FOR REAL? AND WILL IT FIT WITH CAI AEM?
Old Oct 13, 2002
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
Ask yourself the question
An exhaust will give out max 5hp if your lucky, and how much are catbacks running forr? im pretty sure its higher then 89 bucks
If that thing did work im pretty sure 99.9 percent of the population on this board would have of bought this the very first day it came out
Old Oct 13, 2002
RollOut's Avatar
RollOut is an unknown quantity at this point
Has anyone actually tried this out to see if does any good
Old Oct 13, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I know that they work in general. Don't think that they would work too efficiently with our cars.
Edit: found this link in the forum Throttle Body Spacer
Old Oct 13, 2002
macrossranma's Avatar
macrossranma is an unknown quantity at this point
its useless on our cars plus the throttle body spacer wont even fit most of the time if u have aftermarket intake
Old Oct 13, 2002
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
throttle body spacers are retarded on a car with MPFI. they are great if you have a carb..but, umm...im pretty sure ours dont...(note sarcasm)
Old Oct 13, 2002
mikalem's Avatar
mikalem is on a distinguished road
Hmmmm well summitracing is a reputable company though.... I wouldn't see them selling something that doesn't have value in one way or another. Just don't expect 20 hp out of it, maybe 5 if you are lucky......
Old Oct 13, 2002
Old Oct 13, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
i was going to get this and researched it, but decided against it cause it wont fit with my intake. it does help your engine breathe more air, good for a little hp, and also produces a whining sound at high rpms. you have to have at least a one inch gap between the highest part of your intake and the underside of your hood for it to fit. if you get this, dont use a paper gasket, use the silicone high temp gasket maker stuff. otherwise the paper gasket can get sucked into the tb causing problems. hope this helps.
Old Oct 13, 2002
how does it help the engine breathe more air? it can only get as much as can go through the throttle body at any given time...the only way i can think of is if you modify the plate and turn it into a nitrous fogger system...which would be an idea you could work with...
Old Oct 13, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
not really sure why everyone is sittin here knocking this product. yes, 20 hp is a little exagerated, but i wouldnt doubt that it produces some decent hp. for the price, it cant hurt to buy it, try it, and if you're not happy with it, then sell it to someone on the site. as for people on this site sayin that it wont fit? you people are lame for opening your mouth without even knowing what your talking about... if you tried to put this under your hood, it might be a tite fit, however it will fit. people here are soo quick to reply with negative, ignorant replies...
Old Oct 13, 2002
the 20 hp reference is directed towards the trucks and jeeps which by the way, this is a typical mod for them. the spacer has grooves inside it kind of like a screw, which create a vortex or something to that effect which sucks in more air. thats the best i know of to explain it. i know people who have installed this on trucks and jeeps, but i don't know of any that have put this on a smaller car. and yes it does make a difference.
Old Oct 13, 2002
Bartkat's Avatar
The Vortec is cheaper, it's also a helix gizmo, and it doesn't do anything either. Some of this stuff might work if your car has some serious engineering defects in the intake design, but our cars don't so they are a waste of money.
Old Oct 14, 2002
bo0sT's Avatar
bo0sT is an unknown quantity at this point
is this like that tornado thing on tv?
Old Oct 14, 2002
BLUENVY01's Avatar
no, the tornado is an electrical fan type of thingie that hooks up to your intake, sucking more air into your throttle body faster...
Old Oct 17, 2002
ELaudio's Avatar
ELaudio is an unknown quantity at this point
a FAN cannot "suck in more air". Think about what happens when you put your hand on a hairdryer.
Superchargers and turbochargers compress air thereby increasing it's density. Increase in density = increase in massflow = increase in POWER.
All these fan/electric supercharger/vortex gadgets simply DO NOT work.
Whitexj
Sep 30, 2015 02:04 AM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
Bricoleur
Sep 9, 2015 12:30 PM
