Sponsored by:
Sponsored by: CARiD
Face Gsuge Installation
Old Aug 9, 2002
LuvDatCivic's Avatar
LuvDatCivic is an unknown quantity at this point
I have been doing some reasearch on installing the indiglo face gauges but it seems that a lot of people have problems with their needles afterward i.e it says your going 20 when your going 70 etc...What are the chances of that happening. Will it only happen if you remove the needles? Thanks.
Old Aug 9, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
do not remove your needles!!!!!!!! ever
Old Aug 9, 2002
snoopbag's Avatar
snoopbag is an unknown quantity at this point
My needle on my RPM stick on the gauges because i didn't put enough glue behind them to hold them down. So now the gauges rub against the needle and make it stick.
Old Aug 9, 2002
civic510's Avatar
civic510 is an unknown quantity at this point
The chances of screwing up the calibration of the needles are zero if you don't remove the needles.
Old Aug 9, 2002
Engineman's Avatar
T.V. is bad for you. Go outside.
Engineman is an unknown quantity at this point
Hey I put mine in no prob and even took off the needles. I know this is stupid but I adjusted the tack by holding the car almost wide open so it would hit the limiter and set the tack there. As for the speedo it was an educated guess that paid off. Had my buddy drive my car 70 mph while I was on my bike. Perfect.
Old Aug 9, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Quote
[hr]Originally posted by: Dbone39
I have been doing some reasearch on installing the indiglo face gauges but it seems that a lot of people have problems with their needles afterward i.e it says your going 20 when your going 70 etc...What are the chances of that happening. Will it only happen if you remove the needles? Thanks.[hr]
Some double sided tape will fix that right up. And yeah, dont remove the needles.
-Kre
Old Aug 9, 2002
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
Quote
[hr]Originally posted by: civic510
The chances of screwing up the calibration of the needles are zero if you don't remove the needles.[hr]
I MOVED MY NEEDLES AROUND AND THEY RESET, if they mess up its only because they are hittin the gauges and stickin in place. i didnt put any tape on them so i havent had any problems except for right after i installed the needles were messed up for a day until they reset theirselves.
Old Aug 9, 2002
Krista's Avatar
Krista is an unknown quantity at this point
I put double sided tape on my gauges so there not in the way of the needles but they still stick. I didnt remove the needles either, the needle sticks at like 45 and jumps up to 60. If anyone has any idea y its doing this it would b greatly appreciated!
Old Aug 9, 2002
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Krista: it really doesn't take much to make the needles stick, just try gluing/taping them down more and then if it's still doing it, either your cluster is messed up, which is bad (voided warranty with gauges), or your VSS, vehicle speed sensor, is inaccurate. Mess with the gauges a little bit, and then take it to your dealership and ask them to just check the VSS only, and if that's okay, it has to be the cluster.
Old Aug 23, 2002
Krista's Avatar
Thanks for the help RiceBurnrEX....Im gonna install a reverse indiglo gauge this weekend (the blue/green indiglo gauge is to bright for me) so I will mess with the needles when I do that! If that doesnt work I guess its off to the dealership[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
Misfit2613
Jul 30, 2015 09:49 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
