2002 civic coupe altezza install
Does anyone know where their is a DYI guide on the web or anywhere wheir I could see how to install the euro altezza lights in a 2002 civic EX coupe. Thanks.
I hope that's the most complicated mod you are planning on getting. Just pull back the carpet use a socket wrench, loosen the bolts....pull out stock light, put in altezza tighten bolts, wa-lalllalaaaaa...!!**!**^*!* Magic good luck.
just attempt, believe me you'll succeed.
yeah what konig said! there will be one plastic screw to remove the carpet. next there will be 4 bolts to remove that attach the break light to the chasis. . the oem light slides out and you replace withe the new altezza.
make sure you unplug the light bulbs befor trying to remove the oem light. the insturctions on removing break light bulbs are in the owners guide.
goodluck
[IMG]i/expressions/beer_yum.gif[/IMG]
if you have problems pm me and i'll help you sort it out.
goodluck
CarStuff
Dec 6, 2020 12:52 PM
smmahan
Apr 15, 2015 08:17 PM
