Sponsored by:
Sponsored by: CARiD
Rods??????
Old Jun 9, 2002
SilverBUll8's Avatar
SilverBUll8 is an unknown quantity at this point
Rods??????
Ok I know there are posts about Pistons and Rods. I know where to get Pistons from but where do i get rods from? the same people and how much?
Thanks for the info.
S
Old Jun 9, 2002
greg2k1's Avatar
greg2k1 is an unknown quantity at this point
Just curious? How come your looking for rods?
Old Jun 9, 2002
Well dont know alot about cars. Not yet anyways. I want to buy pistons dont i need contecting rods? Cause I a'm bout to get Nitrous (THere for all you fools that dont like people to say NOS for short [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]) And i want to beef up my car alil bit so that it wont kill my car. So if anyone can tell me the info i need.
S
Old Jun 9, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
depends on the amount of N2O you will be injecting. If more than 75, you will need alot of things, forged pistons, rods, balanced, blueprinted, clutch, lower cr, injectors, pump, rail, ecu, VAFC, Cam, springs, and many other things to make your motor strong enough for lots of Laughing gas.
Learn more about cars before you go nuts with the "NAWZ"
Old Jun 10, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
Quote
[hr]Originally posted by: SilverBUll8
S[hr]
Nitrous is pretty stressful on the pistons, so if you plan on running nitrous for any lengthy period of time or if you want to run a large amount (greater than a 50 shot), you should think about getting forged pistons. For serious nitrous apps, rods are also a good idea, but upgrading the pistons should be your first priority if you're serious about squirting. Note that this a little different than a turbocharger scenario, in which case you would be looking at upgrading your entire block (pistons, rods, sleeves, etc.)
To answer your original question - Probe, Eagle, and Crower are three manufactures that make aftermarket rods. To my knowledge, they don't produce any off-the-shelf rods for the EM Civic, but I'm sure they'd be happy to make some custom ones for you for the right $$.
Old Jun 10, 2002
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
I've always wondered, will beefing up your internals provide any power increase?
Old Jun 10, 2002
01civ01's Avatar
01civ01 is an unknown quantity at this point
internals are expensive, crower told me $3600 for a stroker kit (rods, pistons, bearings, and factory crank) not worth it for the gains you will get.
Old Jun 10, 2002
Quote
[hr]Originally posted by: 01civ01
internals are expensive, crower told me $3600 for a stroker kit (rods, pistons, bearings, and factory crank) not worth it for the gains you will get.[hr]
Is that all the stuff i need to beef up my car so that the nitrous wont hurt to bad [IMG]i/expressions/face-icon-small-smile.gif[/IMG] for the engine part. I know i will need a new clucth and stuff.
Old Jun 10, 2002
AEMcivic's Avatar
AEMcivic is an unknown quantity at this point
Quote
[hr]Originally posted by: LJ
I've always wondered, will beefing up your internals provide any power increase?[hr]
It probably won't give you any more HP, but it will be able to handle more HP. (if that makes any sense)
For example, if you have a turbo on a stock engine, you may only be able to run 4 or 5 lbs of boost safely. But when you upgrade your internals, you can run more boost, which creates more HP. And with Nitrous, most people will tell you not to run more than a 50 shot (+50hp) on a stock motor. But depending on how much you upgrade your internals, you may be able to run a 75 or 100 shot. So basically, I guess what I'm trying to say is....if you upgrade your internals, you'll be able to produce more HP before you blow your motor.
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
Butterfli13
Aug 12, 2015 11:04 PM
17
Jul 23, 2015 11:48 PM
