MY CAR HAS THE WORST RIDE
Old 05-21-2002
luv2playu's Avatar
luv2playu is an unknown quantity at this point
Can i get some help and feed back on what do u think are the best springs for my 01 civic, or what camber correction would help?: [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old 05-21-2002
netcbc's Avatar
netcbc is an unknown quantity at this point
Worst ride as in stock? Do a search, there are tons of springs, but to start you off
go to parts section, look up springs and camber kits, decide whatever height you want
Old 05-21-2002
HShadow's Avatar
Springs: Eibach, Great springs. Neuspeed, also great. Camber: Ingalls, or Eibach would be a safe way to go. Check your shocks. Might have blown. If your talking about handleing, put some strut bars if you dont have any.
Old 05-21-2002
Bartkat's Avatar
Get a good set of springs, a set of Koni sport shocks, front and rear strut bars, go up two sizes in tire width, pick the size wheels you want, get lighter wheels. Install all that stuff and find the Koni setting that suits you and go.
Old 05-21-2002
luv2playu's Avatar
Ok but the thing is I have v-spec coilovers and the drop is the best it's the low but not too low and i heard if i go with something other than coilovers my back will always be higher than the front.
Old 05-21-2002
HShadow's Avatar
Sounds like the shocks might be the prob. Unless those coilovers, which I have never heard of, might be giving you the prob. I was told to go with ground control if I was getting an adjustible spring.
Old 05-21-2002
Bartkat's Avatar
<< Ok but the thing is I have v-spec coilovers and the drop is the best it's the low but not too low and i heard if i go with something other than coilovers my back will always be higher than the front. >>
You needed to say that up front, dude. Screw this.
[IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG]
Old 05-21-2002
HShadow's Avatar
That dude is a girl dawg. I think you need to say something to her.
Old 05-21-2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
In general, that's usually true. A set of springs will usually lower more in the front than the back. Are you using your factory shocks? If so, that's probably why your ride quality is so poor. I suggest upgrading to some Koni yellow shocks (I'm using Koni's with Ground Control coilovers, btw).
Old 05-21-2002
The Standard One
VNlilMAN's Avatar
its probably because 1 it's v-spec and 2 their coilovers... and NO NOT ALL SPRINGS WILL HAVE THE BACK HIGHER THEN THE FRONT. i have neuspeed sports(for 2 door) and its a 2 finger gap all around. but ya if you want a more comfortable ride you should get some new shocks. i personally think konis+coilovers are a waste because you could get true coilovers for just a lil more. i havn't been inside a car with true coilovers but i'm guessing the ride is as good as stock or even better
Old 05-21-2002
luv2playu's Avatar
DAMMMM thats what I need thats really helpful thanks. Ya I am on stock shocks, how much do those run around??
Old 05-21-2002
luv2playu's Avatar
What type of schocks are there and which do you suggest??
Old 05-21-2002
The Standard One
VNlilMAN's Avatar
only shocks available right now are the konis, i think they go for 550. they are only inserts tho meaning you have to cut/modify your stock shocks in order to put them on your car. i've heard installation on those were 200. tokico's are supposed to come out soon, not sure when tho. these wont be inserts but will be full struts n will probably be around 500(tokicos are usually cheaper but since they are full struts and not shocks they are still pretty expensive). but ya like i said i dont think its worth it to get konis cause true coilovers are what 1000? i've even seen some for 800. n thats basically the same price as konis+coilovers. right now i'm riding on neuspeed sports with stock shocks, ride isn't too badd, its almost like stock. when the shocks blow(it probably wont be for awhile tho) i'll probably go with true coilovers.
Old 05-21-2002
luv2playu's Avatar
Ur my kindda Man! I appreciate the info on my car it really give me a heads up thanks guys
Old 05-21-2002
deathor's Avatar
deathor is an unknown quantity at this point
Oh yeah, and are you saying it has the worst ride, because in the back of your mind, you're comparing it to stock? Just a reminder (u probably already know this or u might not), you sacrifice ride quality anytime you lower your car. I used to have this debate.. quality or performance? But now, I'm debating other stuff.. hehe..
Old 05-22-2002
Bartkat's Avatar
<< That dude is a girl dawg. I think you need to say something to her. >>
Girl, shmirl. This whole thread is misleading from the start. You say something to her.
Old 05-22-2002
CHARSIUBAU's Avatar
CHARSIUBAU is an unknown quantity at this point
luv2playu
i will save your life....
here's the deal, the main problem you have are those v-spec coilovers.
get rid of them suckas....
i had those same coilovers on my 2k1civic, and it caused me many problems......
i had them taken out.......
i was told that they would settle down and give me a better ride, but it never happened.....
i spent a lot of extra money to take them off and replace them.....
those damn things didn't even lower my car as much as i wanted...
you can email me if you want to know more details about the things i went through with
those coilovers....
i eventually purchased a set of neuspeed racing springs and i am very happy with
them....
Old 05-22-2002
HShadow's Avatar
Those true coilovers that were $800 were the NEX coils. I have head good things, and bad about those. Good the ride, was great, Bad, something about oversteer. 2cute who is a member here was talling me about that problem. Your best bet if your going to go with the true coilover is wait for the Tien coils comming late in the year. Other then that I would consider changing those coils and start looking into maybe ground control or H&R.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
vtec92
05-04-2017 03:20 AM
bsmiley
04-27-2015 01:27 PM
Dorval Andre
04-20-2015 05:34 PM
GH04si
04-15-2015 08:13 PM
Quick Reply: MY CAR HAS THE WORST RIDE
