Sponsored by:
Sponsored by: CARiD
Broken stud
Old Sep 1, 2015
amrhamed's Avatar
amrhamed is an unknown quantity at this point
Cool Broken stud
Hello everyone , i had a broken stud in the crank case (oil pan) for honda civic 2000 LX , so i am planning to drill it then use a thread tap to rethread the hole but i need help with the detailed measurement of the stud to buy the right tap
Regards
Old Sep 1, 2015
Re: Broken stud
Is it a bolt that secures the oil pan? If so, pull one of the other oil pan bolts and use one of those to get the fastener dimensions.
Old Sep 1, 2015
amrhamed's Avatar
Re: Broken stud
it's at the corner
Old Sep 1, 2015
Re: Broken stud
http://www.hondaautomotiveparts.com/...LOCK+-+OIL+PAN
I'm guessing it's #21. There's 4 of em. Pull one.
Old Sep 1, 2015
amrhamed's Avatar
Re: Broken stud
Yeah but i am not following what is 6x28 ??
Old Sep 1, 2015
Re: Broken stud
The stud is 6mm wide, 28mm long. Just no thread pitch information. Probably M6x1.0, but that's just a guess
Old Sep 1, 2015
Re: Broken stud
Common M6x1.0, and you could thread the nut from the stud in question onto any of the other bolts that have the same pitch.
Old Sep 1, 2015
amrhamed's Avatar
Re: Broken stud
but i think it's too thinner than 6mm wide , i gonna buy a gauge anyway
Old Sep 1, 2015
Re: Broken stud
It's considered a 6mm.
Just take a pan bolt in with you if you need an example to match up, that's the exact same thread diameter and pitch.
Old Sep 1, 2015
amrhamed's Avatar
Re: Broken stud
Ok last question , i have a small remaining part of the stud coming out should i removed by carving tap or what .. my best
Old Sep 1, 2015
Re: Broken stud
carefully drill it out a bit and use a screw extractor?
If, by chance, you accidentally drill out the threads, you can try tapping it with a larger tap (assuming there's adequate room to do so) or helicoil it to "restore" the threads.
Old Sep 1, 2015
Re: Broken stud
Vise-grips?
If you can get it to come loose, you should then be able to unscrew it.
If drilling is necessary, I'd use left-hand drill bits. With great care and caution
Crazygrlinak
Oct 8, 2015 05:06 PM
siliconvalley
Sep 15, 2015 09:48 PM
Dave Brabant
Sep 9, 2015 08:11 PM
mrwhos
Aug 11, 2015 02:03 AM
