Sponsored by:
Sponsored by: CARiD
Spark Plugs
Old May 9, 2002
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
Spark Plugs
I can't seem to find the info I want on spark plugs on this site so I'm gonna post some good info and ask some good questions.
These are the stock plugs for our car:
DX/HX/LX - NGK Platinum PZFR6F-11
EX Auto - Denso PKJ20CR-M11
I can follow the NGK's spark plug part #.
p=platinum
z=extended gap
f=ø 14, 19mm (3/4”) Reach, 16mm (5/8”) Hex.
r=resistor
6=the heat rating of the plug (NGK's range from 2-11, 2 being hottest)
f=the firing end construction code
11=1.1mm/.044" gap
Now, can anybody tell me how to read the denso plugs??
Heres what I'm guessing .. please tell me if im wrong
P=platinum
KJ=14mm thread, 16mm hex, ISO plug
20=the heat rating of the plug (densos range from 9-37, 9 being hottest)
C=electrode projection (5mm)
R=resistor
M=??some special gap configuration, but i dont know what??
11=1.1mm/.044" gap
i could be way off on alot of this denso stuff, please correct me if i'm wrong. I'm just trying to get this spark plug thing under control.
Also, 2k1KonigCivic is running nitrous on an LX, im assuming he needs a NGK PZFR8F-11 plug if he wants to stay NGK. Again, please correct me if im wrong.
Thanks,
Eric
Old May 9, 2002
wh3nw0rdsesc4pe's Avatar
wh3nw0rdsesc4pe is an unknown quantity at this point
Thanks E, I need to know this to, don't want to mess things up... let's get this figured out, I am currently running NGK BKR7ES-11's as recommended in the Nitrous thread, they are just not cold enough, I checked them after running nitrous last night and they were white as a mother.... so I know that the plug was my problem, 93 octane, octane booster and a 55 shot. So what plugs for nitrous. I heard something about not running the 11's of the NGK's but I was unsure... so any help out there?? Delecampos??
Thanks all
Team EVO
Joel
Old May 9, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
You oughtta get a hold of NGK's tech support. They should be able to tell you everything you need to know about the appropriate spark plug applications.
TJ
Old May 9, 2002
delacampos's Avatar
delacampos is an unknown quantity at this point
Konig... the 11's are incorrect. those are pre-gapped at .44. you want the BKR7E. the part # is NGK-6097. these come pre-gapped at .30
Old May 9, 2002
does it matter that the brk7e is only 1 step colder than the stock plug? im sorry, i was always told to run 2 steps colder, but im not for sure..whatcha think
eric
Old May 9, 2002
thanks delecampos I heard that, but wasn't sure, appreciated. Are you running a 75 wet shot safely?
Old May 10, 2002
anybody running Nitrous..please tell me what kind of plugs you are using....pleeeeeaze
thanks,
e
Old May 10, 2002
delacampos's Avatar
sorry it took forever for a reply.
Red... just go with the bkr7e's. there was a big debate over this a few weeks ago on www.clubsi.com. by reading the plug, it does indicate them to be only 1-step colder when in reference to what the manual says. however, these are pretty much the standard in plugs when it comes to nitrous and imports. they are sufficient enough for our applications. i use them and i have yet to encounter any problems. to be honest, i don't know anyone that is using 8's.
konig... i feel i am running the 75 shot as safely as i can, given the limited availability of fuel and ignition upgrades. i have yet to encounter any problems these last 9 months or so with my 75 shot. what else can i say?
Old May 10, 2002
sweet if you don't mind could you tell me your engine upgrades??? I need to know what I can do to run a 75 shot safely, you can PM them to me, your secret is safe with me...lol.
SimpleUser
Apr 24, 2021 02:54 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
