Sponsored by:
Sponsored by: CARiD
PIAA fog lights @ Costco?
Old May 1, 2002
XoULaBeAT's Avatar
XoULaBeAT is an unknown quantity at this point
How much are they usually? Those oval ones.
I found them on Costco today and they were selling for 60 bucks. With installation kits and everything.
Is it worth it or is it expensive? I dunno. Someone tell me.
Old May 1, 2002
Mystic77's Avatar
Mystic77 is an unknown quantity at this point
i think piaa fogs go for aroung 70 bucks at pepboys. it sounds like a good deal. i would try shopping around to be sure though.
Old May 1, 2002
Exbauer's Avatar
Exbauer is an unknown quantity at this point
Those PIAA fog lights at Costco are not worth the $60. They are only 35 watts and your headlights over power them. So, basically they are worthless. I would recommend the OEM like fog lights. They are from Procarparts.com and they are around $100. You cannot tell the difference from the OEM ones. They look exactly the same. They come with everything needed to install and there is no need to splice wires. Plus, they are 55 watts.
Old May 1, 2002
Intruder's Avatar
Intruder is an unknown quantity at this point
They aren't PIAA's, they are generic ones at that price, the cheap PIAA's (solitaires) go for around $100, the rest start at around $160 and go up from there. Peace
Old May 1, 2002
SatinSilver2k1's Avatar
SatinSilver2k1 is an unknown quantity at this point
mine were $160 and they are so damn bright..
Old May 2, 2002
XoULaBeAT's Avatar
<< Those PIAA fog lights at Costco are not worth the $60. They are only 35 watts and your headlights over power them. So, basically they are worthless. I would recommend the OEM like fog lights. They are from Procarparts.com and they are around $100. You cannot tell the difference from the OEM ones. They look exactly the same. They come with everything needed to install and there is no need to splice wires. Plus, they are 55 watts. >>
Hmm, interesting. I did not know that at all.. So I should get it the OEMs? Is there anyway to change the bulbs on that? I mean it's yellow, I want blue or white or something kekeke
Thanx for this good info.
Almost raped 60 bucks there..
Old May 2, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
I have the PIAA's from Costco installed & they're Hella White.. They are not Generic ones ...My local Costco now sells them for $50, the same ones sold on another web site run $100. These are the deal of the Century...Pick them up while you can....None of these guys have actually seen them in action. I have, TRUST ME.....
Old May 2, 2002
Mbow's Avatar
How about a model id or number for these $60 piaa lights. That is hella cheap. I wish I had time to go over to Costco.
Old May 2, 2002
Exbauer's Avatar
I had them, they are just sitting in the garage because I got the OEM like ones. The PIAA ones are called Solitaire...oval in plastic casing and lens. They do nothing for output. Just get the OEM like ones. The bulb is yellowish, but companies will make bulbs for them later. They are bright and illuminate the road real well.
XXLUV2EXCELR8XX
Dec 16, 2001 04:56 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
CivicS
Nov 22, 2001 10:51 AM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
