Sponsored by:
Sponsored by: CARiD
Which is better...19mm or 22mm rear sway bar?
Old May 1, 2002
Exbauer's Avatar
Exbauer is an unknown quantity at this point
Okay, I did a search and came up with no real definate answer to which would be better. If I am not mistaken, the neuspeed and RSX rear sway bar is 19mm. But, will the 22mm be too much? A lot of the threads say the 22 mm will cause oversteer or understeer...one of those. Then, somebody called Neuspeed about using a 22mm bar and they said it would not be wise. The 19mm is perfect for the street. So, for the people that have the 19mm or 22mm does it satisfy your needs? Also tell me if you are statisfied with your purchase.
Old May 1, 2002
artychris's Avatar
artychris is an unknown quantity at this point
I got the 22mm on order. They should be coming in next week. 19mm is safe for the street because it's going to be more predictable and it's probably more ideal for the Civic. I prefer a larger bar because I hang around drifters and I am purposely dialing in my car for more oversteer. With my skills, I should be able to handle a 22mm bar without a problem, and when my suspension is fully tuned, (coilovers, forged wheels, alignment, Torino's, strut/tie bars, etc..) I'm going for the Mugen 26mm rear sway. Now that's oversteer!
Old May 1, 2002
JBlazeVA's Avatar
JBlazeVA is an unknown quantity at this point
i think 22mm is better???? i do not know for sure
Old May 1, 2002
HTOWNBOY's Avatar
HTOWNBOY is an unknown quantity at this point
thicker is better!
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] 2K1CIVIC1solo.JPG (31 Kb)
Old May 1, 2002
Grey's Avatar
DIY King
This is a re-post of a conversation I had with CivicVTec:
I did some more calculations and I had some discussion with my father and we came to the conclusion that a 22mm sway bar is the way to go.
We checked out the stiffness compared to the weight.
So...
(22/24)^4 gives us the relative stiffness of the 22mm rear sway bar to the 24mm front sway bar. This means that the 22mm sway bar is about 70% as stiff as the 24mm front sway bar.
The weight distribution is 40% in the rear and 60% in the front. This gives us the ratio of back-to-front weight of 40/60 or 67%. This is almost the same as the stiffness ratio mentioned above. Therefore we have almost the same rear-to-front stiffness ratio as we do the rear-to-front weight ratio.
In comparison, (19/24)^4 gives us the relative stiffness of the 19mm rear sway bar to the 24mm front sway bar. This means that the 19mm sway bar is about 40% as stiff as the 24mm front sway bar.
Old May 1, 2002
Exbauer's Avatar
I would like to get some input from people that have the 19mm, 22mm, or both and tell us how the handling has changed and if it is dramtic.
Old May 5, 2002
TOOLOWCIVIC's Avatar
Where is the best and cheapest place to buy a 19mm sway bar?
Old May 5, 2002
Exbauer's Avatar
I think the cheapest place I have found is HERE.
Old May 5, 2002
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
like Grey said...u dont want those...it's better for u to get the whole set
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Marco83
Oct 13, 2018 10:13 PM
GotSiR
Jun 23, 2016 04:06 PM
muniorbust
33
Aug 31, 2015 08:59 PM
