Sponsored by:
Sponsored by: CARiD
hood won't close all the way?
Old Jan 1, 2012
dagilab's Avatar
dagilab is an unknown quantity at this point
i have a 2008 honda civic coupe and i am trying to install an aftermarket hood by myself. After installation, won't close all the way? It doesn't make the second click like the stock hood which makes the car alarm sound. I have tried pushing it all the way down, but it didn't work either.. Is there any way to fix this? I measured the hood latch part on the old hood with the new one and it seems to be shorter than the other. I don't know if that's the problem.. but is there any way to adjust it?
I have also tried contacting contact support with the hood i bought it from and they said about some bump stop can be adjustable or the hood latch can be moved up. If so, is there any tutorials?
here are some pictures to explain what I am talking about.
http://s18.photobucket.com/albums/b1...Civic%20Coupe/
Pictures shown is with and without the aftermarket hood. The one that is measured 1 1/2" is the stock hood.
Old Jan 1, 2012
Re: hood won't close all the way?
Adjust the hood latch upward.
Old Jan 2, 2012
dagilab's Avatar
okay i will try that. thank you
Old Jan 2, 2012
dagilab's Avatar
is there a tutorial online on how to do it? and do i need to remove the front bumper?
Old Jan 2, 2012
Remove the plastic panel covering the latch.
Loosen bolts for latch.
Move latch to desired position.
Tighten bolts.
Check if you moved latch far enough. Close hood. Does it latch now?
Readjust as necessary until hood closes and latches.
Put car back together.
Old Jan 2, 2012
dagilab's Avatar
i removed the bump stoppers that was in the middle and now it fits perfect. there's a gap on the drivers side after closing it, but meh.. got it closed
Old Jan 2, 2012
Those stoppers are there to adjust the height of each front corner when it is closed.
If the hood isn't centered, you need to make some adjustments at the hinges or the latch so it closes straight and sits flush.
Bad fitting parts look amateurish.
Civic15
18
Sep 19, 2017 07:48 PM
orangeju1ce
Jul 14, 2015 08:32 PM
beeemerdude
Jul 10, 2015 09:22 PM
Trennytrent
Jul 10, 2015 09:01 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
