Sponsored by:
Sponsored by: CARiD
quick short shifter questions (no need for a big debate)
Old Apr 29, 2002
Russps's Avatar
Russps is an unknown quantity at this point
ok, I know there is a major short shifter discussion going on, and this may have been covered in it (or other discussions), but here it goes. I know our choices for shifters are adapters (DC, Solo, Neuspeed, etc) and the entire assembly (Revo). Now, I know based on previous posts that the Revo is a shorter arm (it doesn't stick up as high), but does it ALSO change the pivot point as the adapters do? Also, how much shorter than stock is the revo shifter? I have the aluminum RSX shift **** which is already lower than the stock shift ****, and I don't want to lower it much farther (if at all). The last question, is there a difference between the different brands of shift adapters, or are they all pretty much the same except for the name stamed on them?
Thanks in advance.
Old Apr 29, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
w/ the full revo assembly
not only does it lower the shift height by 1.5 inches, but it also does reposition the cable mounts to actually decrease the throws
i cant wait to buy one [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Apr 29, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
The REVO is shorter by about 1-1/2 and it also relocates the cables as mwwhonda stated earlier. I was concerned about the overall height also, but after installing mine, I think it is at the perfect height for the car.
Old Apr 30, 2002
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
i just have the Neuspeed Adapter, im thinkin about gettin the REVO to go with it, and the Bushings. But so far i am VERY pleased with the performance of the shifter. I can snap my shifts off as fast as i can move my foot to slam the clutch down and pop it back up...(VERY quick). Just want to make sure though...the REVO will fit with the adapter that i already have right? And the bushings? If someone could clarify that for me, that would be great. If not the REVO, then i'll jsut end up gettin the bushings ($20).
Old Apr 30, 2002
BAK's Avatar
BAK
The bushings will work perfectly with either setup. I'm not sure if the Neuspeed adapter will work with the REVO. I've heard someone say that certain brands of adapters will fit and others won't.
Old Apr 30, 2002
Mbow's Avatar
If you don't won't to lower the height of the stick, then go with an adapter. The revo lowers it a good bit and is very noticeable to say the least.
The different brands are probably pretty comparable if you ask me. I think the solo is the particular model that someone managed to integrate with the revo.
Get the kumho bushings when you pick up the adapter. They are like 26 bucks shipped and well worth it. I say the adapter because it's your only choice if you don't want to lower the height of the stick.
Supramk3
Jun 11, 2015 11:13 AM
MyCivic
Nov 21, 2001 02:11 PM
StLVtec
Nov 14, 2001 09:22 PM
CIVICINJEN
Nov 6, 2001 01:30 PM
GreenVenom
Nov 6, 2001 12:47 PM
