Sponsored by:
Sponsored by: CARiD
View Poll Results: Which of the three do you like my car is Titanium metalic, limo tint, dark gray rims.
Red most like the stock 05 lights
27
64.29%
Black
16.67%
Smoke
19.05%
Voters: 42. You may not vote on this poll
Which LED tail lights? poll inside
Old Sep 27, 2010
  #31
MoreRicePlease's Avatar
MoreRicePlease has a spectacular aura aboutMoreRicePlease has a spectacular aura aboutMoreRicePlease has a spectacular aura about
Re: Which LED tail lights? poll inside
I know, But where's the best place to get em? Do they fit an '02?
Old Sep 27, 2010
  #32
i got em off ebay, they are still kinda pricey tho even used. from dealer they are around $200 for the set (www.hondaautomotiveparts.com) and fits 01-05 sedans direct bolt on and uses all the same bulbs.
Old Sep 28, 2010
  #33
By far the best tail's for the sedans! God, I want them! I have a pretty good excuse too. My left tail is cracked so after a good down poor, rain leaks into my trunk when i open it.
Old Sep 28, 2010
  #34
there you go, order some asap lol
Old Jan 8, 2011
  #35
longdrive352's Avatar
longdrive352 is an unknown quantity at this point
Did you end up going with the ebay brake lights ? If so, how did they turn out ? I'm driving a 97 HX, and spend a lot of time on the road. I'm really interested in the most "visible" option for tail lights. I've looked at superbrightleds.com, but I'm really interested in hearing if the whole assembly with the LEDs was bright or not.
Old Jan 8, 2011
  #36
i can suggest brighter filament bulbs if you can post your bulb sizes. those ebay led tails are usually cheap and junky and unreliable.
Old Jan 8, 2011
  #37
The bulbs appear to be 7443. Thanks for any suggestions. I really like the idea of the improved reaction time for drivers behind me with LEDs...especially on rainy or foggy days here in central to north Florida.
I'd be willing to shell out the $25/ea for the 7443-R45-T that are listed on the Superbrightled website as their brightest, if I knew people were having good experience with them.
Thanks again.
Old Jan 8, 2011
  #38
those led bulbs dont work. stock filament bulbs are between 300-500 lumens per bulb. those cheezy led bulb replacements are at best 50 lumens. there is no way they could work for a brake. im using a 5w hi power ELEF led bulb ($100 a pair) from elef-usa.com and they use genuine osram smt led with 200 lumens. and even with that crazy brightness, i still had to add my own optics to focus the light and make it intense enough to pass for a turn signal. i have them only in the turn signal as the brake spot would not be practical due to the limited space back there and the angle of the bulb. im still using filaments for my brakes and the brightest 7443 by far is the polarg lens type bulbs from eautoworks.com ($40 a pair but they last a long time).
here is a pic of the modded elef bulbs glued in the turn signal sockets (hole was too small). the turn bulb also points to the side which means it really has to be bright for any chance at seeing them directly behind the car or in the sun. i posted pics of the led bulbs on the first page already, but here are the outputs. if you have the space behind the housing for the larger size bulbs and dont mind widening the bulb hole and gluing them in, it may be an idea. otherwise stick with the polarg filament bulbs for something brighter.
Old Jan 8, 2011
  #39
Well, thats disappointing to hear. If the bulbs aren't backward compatible with decent output, then I wonder if there are any LED tail light assemblies that put out enough light. I saw a kit on an accord (old body) in Gainesville one time that really looked good (and I'm hard to impress).
I may just try some of those polargs you mentioned.
Old Jan 8, 2011
  #40
do you have a coupe or sedan? the coupe has a pretty good aftermarket tail with leds already in it. sedan has one too but its much cheaper looking. coupe ones almost look stock. the first pic in the first post shows the led coupe replacements.
Old Jan 8, 2011
  #41
I've got a coupe. I was actually most curious about the ones that look stock. Those are right up my alley if they work well. Seen any feedback on them ? I thought you were saying that those weren't any good on Ebay. You may have just been talking about bulbs in that first post.
Old Jan 9, 2011
  #42
yeah those should be nice and bright. the leds are fairly good quality and have built in reflectors. i would try em out. yeah i was referring to the led pnp bulbs being bad. altho most full led tails on ebay arent great either. the style in the first pic is good, i havent heard of any problems with em.
Old Jan 9, 2011
  #43
sl33pyriceboi's Avatar
read/look at the first page.
i have them. the quality is the same as OEM. perfect fit, LEDs are bright (ive had em for about 2 years now, and none has dimmed or burnt out).
did i mention they're bright???? it uses superflux leds so they are pretty well lit
Old Jan 9, 2011
  #44
Olliemo's Avatar
Olliemo is an unknown quantity at this point
Originally Posted by sam68
Does anyone have the TYC stock 05 replacement tails? Do they closely match the OEM's? Are they good quality? I can't find a decent price on used 05's around $150 used. I can get them new for $190 the TYC's are like $130 shipped, thinking about just buying new but if the TYC's are good I can save some $.
Originally Posted by gearbox
the quality is terrible. at least with my sedan tails from 04-05. the aftermarket oem style part has a poor chrome finish, different (bad) reflectors for the bulbs, dark red tinted plastic instead of oem red-orange, and a bunch of other issues. oh yeah, it would not even fit on the car! there was a huge gap on one side. luckily it was only 1 of the 4 pieces and i ordered an oem piece from the dealer to match the rest. and yeah, it fit together perfectly. so yes, definately stick with oem honda for lighting.
were you referring to the tyc tails being crappy? (crappy looking or crappy quality?) I've been looking at some for the sedan, i thought they made quality products.
Old Jan 9, 2011
  #45
tyc makes good stuff but i dont think they have any led tails. i have tyc headlight projectors and think they are good quality. in that quote above, i was referring to the depo brand "honda replica style" tails that look pretty much the same as oem. they had alot of issues tho.
these are the sedan depo led tails, the only ones that i know of for sedan. they were very bright and use the same square superflux leds as the coupe tails in first post, but i didnt like the style. too cheap looking for me. as far as function, yeah they had no issues. no water leaked in, and the leds were way brighter than stock tails and used almost no power. i have alot more pics if anyone is interested in getting these.
parking lights were all leds on all four pieces
turn and reverse used the stock bulbs and not leds (except you need an amber bulb for the signal since the lens is clear now)
the brake lights function similar to factory where only the outer pieces come on. if the park lights are already on, the outside leds get brighter (it uses PWM dimming like most oem cars do to reduce brightness)
closeup of the outer leds and reflectors for park/brake
this is the park light brightness against a wall
this is brake lights
and brake on the ground
during the day
at night with parking lights
closeup
during the day again
Old Jan 9, 2011
  #46
i have these tyc projectors now, no complaints
i used to have these tyc tails, but i think i outgrew the style lol. also no complaints, no leaks, good brightness (but uses stock bulbs not leds).
Old Jan 9, 2011
  #47
MindBomber's Avatar
Live for the Twisties
+1 I've only ever heard good things about TYC headlights, they're definitely a step-up from the ebay projectors most people buy.
Old Jan 9, 2011
  #48
nice fart cannon gear.
Old Jan 12, 2011
  #49
Olliemo's Avatar
good to know gearbox thanks again!
Old Sep 15, 2011
  #50
eric2000cool's Avatar
eric2000cool is an unknown quantity at this point
I will go red
Old Sep 15, 2011
  #51
Red for sure, classic look
Old Sep 24, 2011
  #52
ibanez6686's Avatar
ibanez6686 is an unknown quantity at this point
I have an 03 coupe. For those first tail lights on the first page would I have to do the 04-05 converson?
Old Nov 29, 2011
  #53
Chucky00civiclx's Avatar
Charlotte00Civic
Chucky00civiclx is an unknown quantity at this point
I have a 2000 Civic LX sedan and have been looking everywhere for LED tail lights preferably ones that r smoked or red/smoked do you know of anywhere that will have them i want them to match my r8 style LED projector headlights im getting next year.
Old Nov 29, 2011
  #54
search ebay for "00 civic tail" or 00 civic led tail something like that. there are too many matches to post them all here.
Poopies
Apr 20, 2017 11:36 PM
Erndog81
Oct 31, 2015 03:01 PM
shaejb15
Apr 12, 2015 11:38 AM
blackbullet
Dec 1, 2001 03:44 PM
