Sponsored by:
Sponsored by: CARiD
Suspension Set-Up
Old Apr 11, 2002
ELTsanwich's Avatar
ELTsanwich is an unknown quantity at this point
Suspension Set-Up
I read all the time in the forums of people blowing their stock struts when using an aftermarket spring with an agressive drop. Heres my proposed set up:
Koni Yellows
Neuspeed Sport Springs
Dc Sports or Neuspeed front upper strut bar
Chamber kits
do i need chamber kits witht the konis? i heard somebody say that u didnt. i know the suspension questions are getting old.
Old Apr 11, 2002
HCivic's Avatar
HCivic is an unknown quantity at this point
should be camber kits instead of "chamber kits" [IMG]i/expressions/laugh2.gif[/IMG]
for neuspeed sport springs, you will probably need camber kits cuz of the 1.75front/1.5rear drop.... unless u want to change new tires like once a year which will cost u way more than a one time camber adjustment.
Old Apr 11, 2002
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
koni yellows. i recommend the nuespeed sport springs. not a significant drop, but hey! you have koni yellows... both ride and height adjustable. wanna adjust the height? jack up your car so the spring is loose... lower the collar that holds the spring to the next drop... and BAMN! your car sits another inch lower! im not sure about the 7th gens though. my friend has koni yellows w/ eibach pro kit on his 96 civic hb.. a very good setup in my opinion... eibach prokit is a 1inch drop.. after adjusting the height... his car sits around.. um.. 2inch drop? basicly 1 finger gap from the fender well. camber kit? yes you need it! camber has nothing to do with spring and struts set up... its the angle of your wheel... so the camber kit is a must.
Old Apr 11, 2002
cvc2k2's Avatar
dont get DC sports peice of shizzzz.. get neuspeed.. no pivot joints... do a seach on "sway bar" and "strut bar" u'll find the thread........... okay here. this is the car king. he knows what he is talking aboutDezoris
Old Apr 14, 2002
RockfordFosgateBwoy's Avatar
RockfordFosgateBwoy is an unknown quantity at this point
i thought konis were only adjustable in firmness, not ride height? Anyone want to confirm?
Old Apr 14, 2002
cvc2k2's Avatar
<< i thought konis were only adjustable in firmness, not ride height? Anyone want to confirm? >>
here is a linkDas INteg
go to the paragraph titled Complementary Performance Mods
check it out...
Old Apr 14, 2002
cvc2k2's Avatar
yea... MILD height adjustment.
Old Apr 14, 2002
IonRays's Avatar
IonRays is an unknown quantity at this point
sticker tires/sway bars makes a huge diff if u want 1.0gs on the skid
also polyurethane bushings helps and stiffer spring ratios
heh i dont care about ride quality just how many g's i can push
konis are ok..but i would get jic or tein (which the type superstreet coilover will be out soon)
im waiting for the type RA for the rsx or si ,does it matter? the more the adjustability the better
the coupe already comes with a stiff 25.4mm front sway bar why not get the comptech rsx rear sway 22mm
if ur serious about hugging the road it all about suspension tuning[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Apr 14, 2002
iamboo's Avatar
Retired - SoCal FI Mod
you will need a camber kit.... the koni's are recommended by i suggest you wait for a more inexpensive set of shocks....strut bars work the same... so blah...
Old Apr 14, 2002
GeNoZiDe's Avatar
GeNoZiDe is an unknown quantity at this point
I got the Koni yellows, skunk2 coils, and the dc sports upper front and lower rear tie
i need a camber kit for the back
i maxed the skunk2 drop
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
naokigoffi
Aug 30, 2015 06:19 PM
