Sponsored by:
Sponsored by: CARiD
Civic Crower cam problem
Old Apr 27, 2009
straube63's Avatar
straube63 is an unknown quantity at this point
Exclamation Civic Crower cam problem
I have a 98 honda civic ex, d16y8, and i put in a stage 1 crower cam, ever since i put this in i have had nothing but idle problems, i also have a adjustable cam gear, i have messed with the timing and it is right on and the idle fluctuats and nearly stalls. Any help would be great thanks!
Old Apr 27, 2009
rednwhite04's Avatar
rednwhite04 will become famous soon enough
Re: Civic Crower cam problem
pretty sure you need k-pro or some other form of ecu tuning
Old Apr 27, 2009
straube63's Avatar
any help as to where i can get one of those?
Old Apr 27, 2009
you shouldnt need to tune a stage1 cam. try to reset the ecu and relearn the idle. maybe that will help but i dont think these lo hp engines like to be messed with. ive had nothing but problems.
Old Apr 27, 2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
you can't use k-pro on a 98 civic
Old Apr 27, 2009
skipbarber's Avatar
sounds like your timing is off. a stage one shouldnt give you an erratic idle. Just one tooth off on the cam or crank can seriously mess up your idle. learned that from experience...
Old Apr 27, 2009
straube63's Avatar
how do i reset the ecu, do you have to have special equipment?
Old Apr 27, 2009
straube63's Avatar
ha ha yeah but i just put it in time today using a test light and i lined it right up, so idk what else to do
Old Apr 27, 2009
drive the car til engine is warm. shut off car, then disconnect battery or pull out the ECU fuse. replace, then start car. let it idle for 10 mins without pressing gas or using accessories/lights. make sure hood is closed. turn car off, then turn on and go for a drive. if it still has problems, you need to find another way to fix it.
Old Apr 27, 2009
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
x10000000
Old Apr 28, 2009
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Dont suppose you adjusted the valves? So many people dont understand the concept of valve lash and do cam swaps without doing this or doing it wrong that its not even funny. At best they would be a lil loose and you would trade performance with a noisy valvetrain. If its tight the valves dont seat, sometimes causing poor idle, low vaccuum, sluggish performance, etc. If its really tight you can get spring bind, bent valves, or broken rocker arms, blah blah.
Anyways, I'd double check that first.
Old Apr 28, 2009
wow yeah i forgot the most obvious. the new cam should have come with new valve adjustment specs.
Old Apr 29, 2009
straube63's Avatar
alright thanks guys ill do all of that and see how it turns out and ill get back to you
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
CarStuff
Dec 6, 2020 12:52 PM
Tybonater
Apr 24, 2015 07:03 PM
Myredjonda
Apr 14, 2015 07:00 PM
thesushiboy
Apr 12, 2015 07:40 PM
