Sponsored by:
Sponsored by: CARiD
Who makes steering wheel emblems?
Old Jul 26, 2008
inthezoneac's Avatar
inthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trustedinthezoneac should not be trusted
I have a 2000 civic and I came across this
Problem is it says for 06+ year civics. Since it says that I'm assuming it's a different size from my year emblem. I think it looks nice, not fancy at all but it contrasts well with everything else.
I've already tried contacting them but no response so I'm hoping any of you know where to find one.
thanks
Old Jul 26, 2008
Re: Who makes steering wheel emblems?
too big for your car. and also, it needs a flat emblem to stick on. i believe 6thgen has the H etched into the plastic. newer civic has a flat emblem attached and this sticker just goes on top of it
Old Jul 26, 2008
well I can easily lightly sand it to give it a smooth flat surface. Even if it's not completely flat, as long as there's not too much bend one should still work, right?
I take it no one makes one because of this.
Old Jul 26, 2008
well yeah. the sticker will easily cover the old H, but it will be bumpy. i wouldnt go sanding around there cause it has the airbag underneath. i guess buy one and see if it will fit, then try and smoothen it. i guess you could also fill it with something too
Old Jul 26, 2008
well I wouldn't press on the wheel, but sand it just enough so it's smooth and not grainy. I'm sure it would take a lot of force for the airbag to come out lol, but yeah I may buy it anyway and see if I can trim it down to size.
Old Jul 27, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
You could hit your steering wheels with a hammer, it's not going to cause the airbag to come out.
Old Jul 27, 2008
speedfoos's Avatar
Or just take a razor blade and shave it smooth. You're gonna cover it by a sticker thing anyway.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Optimus34
May 25, 2015 11:52 PM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
