Sponsored by:
Sponsored by: CARiD
Headlight Lens???
Old Jan 3, 2008
breault5's Avatar
breault5 is an unknown quantity at this point
Question Headlight Lens???
Anybody know if its possible to buy just a '02 headlight lens off ebay or the dealership or even privately...due to my headlight lens being all hazed out and stuff dont want to buy a new set just because it looks somewhat bad!!
or any suggestions on how to clean them besides the meguires plastx(curious if that works good or not also!)...
Thanks Guys!!
Old Jan 3, 2008
DsevenEm2's Avatar
This is Myspace
Re: Headlight Lens???
meguires works good but not for extreme hazing.. and it doesnt last that long if you just use it by itself.. youd have to buy something else i forget what i had.. it basically treats the lens for further hazing, but then it goes back to crap after 3 or 4 months..
just get new headlights, save yourself a waste of time.
or another option, you can get them professionaly treated and buffed and all that for like 60 bucks.. check on craigslist for shops or mobile people around you
Old Jan 3, 2008
they have headlamp repair kits where you use sandpaper to clean it up, then progressively finer grits of paper to polish it and as a last step some plastx or scratchx. but then you need to get a plastic protectant and use it regularly because the plastic will discolor from the sun faster. its easier to get some new headlamps but its expensive, and the ones on ebay are usually terrible quality. i got a few there that say good spahe but the lens were all pitted and scratched. its always junkyard stuff.
Old Jan 3, 2008
jdmsiref9's Avatar
jdmsiref9 is an unknown quantity at this point
I have a set of headlights that i have already taken apart. I was going to do a HID conversion but changed my mind. if you are interested. I have pictures and are willing to sell the headlights (2 Headlights Split apart w/hardware). Email me if you are interested. jdmsiref9@hotmail.com
Old Jan 4, 2008
D16Z6_owner's Avatar
D16Z6_owner is an unknown quantity at this point
just wet sand it with finer and finer grits of sandpaper. then hit it with a cutting compound and then wax
Old Jan 4, 2008
breault5's Avatar
thanks for the replies guys but im really not interested in buying a whole new headlight just the lens itself....the only one that is hazed is my left one and its really not that bad..i wouldnt say it is extreme so maybe i will try the meguires! but i have to take the headlight apart thats not very fun but yeah...
any other suggestions of other products or something i dont know if i want to sand just in case i make it worse somehow cause then i would need to buy a new one...
Old Jan 4, 2008
why take headlight apart? all the damage is on the outside. im sure the inner lens is fine. if you dont like sandpaper, get turtle wax rubbing compound. it should remove the bad stuff and make plastic smooth. then use a polisher like plastx to bring the shine back.
Old Jan 5, 2008
breault5's Avatar
really its on the outside??????
i always thought it was on the inside??
Old Jan 5, 2008
nah, uv from the sun damages it. all the halogen bulbs have a uv filter so there is no way they yellow from the back.
Old Jan 5, 2008
LiKEaFeRiO's Avatar
Make sure the lenses come from the exact same headlight as yours or you may have fitment issues.
Headlights from different sources (OEM Honda, after market, coupe, sedan) are sometimes not built with the same contact points (where the black housing meets the clear plastic).
Old Jan 5, 2008
FiveOhFlickr's Avatar
FiveOhFlickr will become famous soon enoughFiveOhFlickr will become famous soon enough
It's possible it could be in the inside though. What if there was moisture inside the housing? If left long enough in there, especially with the sun, wouldn't it haze up in the inside? I was just wondering because I thought that would happen if i didn't clear the moisture in my headlights a few months ago.
Old Jan 5, 2008
almost always, its the uv protective coating on the outside that is applied to the polycarbonate lens that starts to yellow after a while. once you do the sandpaper and polish, you strip it away and leave just the exposed plastic, which will also start to yellow after a few months. which is why you should always seal them with a good plastic sealer every month like the wolfgang stuff. if you take care of them from the start, this would not be a problem now.
Old Jan 6, 2008
breault5's Avatar
alright so how exactly do you do this sandpapering thing??
Old Jan 6, 2008
buy a bunch of different grit sandpaper, going from rough to smooth (the smoothest i think is 2000 grit which is the really fine grey paper for wetsanding. start with big sandpaper, then go smaller and smaller, then use the rubbing compound which polishes even less than sandpaper, after than they should be smooth but dull. so you use a plastic polish like plastx to bring the shine back.
Old Jan 6, 2008
breault5's Avatar
alright thanks guys!!
what is a kind of rubbing compound that polishes??? like turtlewax or anything like that??
Old Jan 6, 2008
skipbarber's Avatar
ive used this exact product 3 times, and it's worked incredibly well. ive tried others but none come close to this one..
http://cgi.ebay.com/ebaymotors/Headl...spagenameZWDVW
ive used it on a Jeep grand cherokee, a camry and a dodge intrepid. the lights were orignally dark yellow and no longer transparent. this product made them as clear as new. you have to take your time with it, but the final product is just amazing. it's just like everyone says.. with this product you use a citrus base cleaner kinda like goo gone in combination with a heavy grit sand paper. once you get the major stuff off, you switch to a finer grit to get a smooth finish. the light will appear really dull, but feel smooth. you clean the light thouroughly once and go at it with the really fine sandpaper. wash it off and clean it with alcohol as best you can. once it's dry the lens will still look really dull. the part that makes this particular product work is the acrylic you lay on top of the lens. you brush on the acrylic as smoothly as possible, it kinda resembles clear nail polish and it goes from wet to tacky in just a few seconds, so applying it fast and neatly will yield the best result. once you finish applying the goo, turn on the high beams for a bit and you basically cure the stuff in about 10 minutes. We charge $100 for the service, but just get it online, the directions it comes with are pretty clear. Just be sure that the damage is on the outside of the lens, if the outside is smooth and the damage appears to be on the inside, dont bother. I've bought 3 sets of headlights on ebay and they've all turned out to be in really good shape, you just have to pay attention to the details and find the right auction by the right seller. just my 2 cents.
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
