help wit clutch noise plz from 05 vic
hey i remember few weeks ago, there was a thread about fixing the clutch noise. i searched through 4-5 pages of each section and couldnt find it. can someone help me out plz or tell me how to fix this problem. i'm sure my clutch is still good cuz i only have 40k miles on it. and the noise happens only when i let off the clutch, pressin down has no noise.
Re: help wit clutch noise plz from 05 vic
search harder. its there.
https://www.civicforums.com/forums/7...pic-added.html
there is also another DIY that takes u step by step but im to lazy to search for it.
i know what ur talking about...i had the same problem everytime i released the clutch it made a squeaking noise...i took it to honda, they lubed it up, and i havnt had any problems since and its been about 8 months or so.
yep, it's your input shaft bearing, like someone said above. honestly if you're somewhat mechanically inclined, it's not too bad to fix. i changed the throw out bearing in my k20a2 this weekend and didn't even have to loosen the subframe. just scooted the tranny around until there was enough room to work. you should probably go ahead and replace your throw out bearing while you're in there, and inspect your clutch and blow everything out with an air compressor or something.
I had a squeak like that at the pedal both going down and coming back up.
Lubed the joint on the slave cylinder, all gone.
You just have to pull the boot out of the way and spray some lithium on the joint.
Another spot common for squeaks is the ball where the release bearing fork pivots. Bit of a pain to lube, but it gets rid of the noise.
Hope this helps
Hope this helps
Anyways...to CivicX3, if you need help replacing that bearing...shoot me a PM...ive done quite a few of them now. haha
Official Rattlesnake Hunter
correct it is the input shaft bearing link for anyone confused...
https://www.civicforums.com/forums/3...save-some.html
is it just me, or this problem more common with the 04-05's? Ive only had to replace the shaft bearing on those, never 01-03's..
how much will it cost if i want to get the bearing replaced? thank all for the reply. greatly appreciated!!! what city you from spoon?
a lot i was quoted about 4 to 5 hundred to rip apart the tranny and replace a $27 bearing.
I got a new tranny installed for 5 insted...
HAHAH...spoon if you live in so cal how can you help me then. well guys i finally had a change to look at the engine bay today, i will take some pic of where the rubber piece everyone sayin to gease wit lithium gease, will this help wit the noise at all or will i HAVE to change the bearing? not sure what to do so how you guys can guild me thru it. ty
06Si_Girl
Jul 12, 2015 12:08 PM
1khilari
Jul 9, 2015 08:12 PM
