Sponsored by:
Sponsored by: CARiD
Reverse gauges by AC
Old Mar 24, 2002
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
My friend is getting the reverse indiglos from AC autotechnic but it looks to me like it has white parts that will cover the warning lights. My question is, will the indicator lights show through the white part? ie; Brake,Fuel,etc.
Old Mar 24, 2002
RSXtypeIvtec's Avatar
Su Mo
where is the cheapest place to get the ac reverse?? havent seen any for under $70
Old Mar 24, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
you can cut trim off those parts and they will work just fine
Old Mar 24, 2002
Narflar's Avatar
Narflar is an unknown quantity at this point
Yeah, just cut that part out. Just don't cut the black parts on the back.
Old Mar 24, 2002
Narflar's Avatar
<< where is the cheapest place to get the ac reverse?? havent seen any for under $70 >>
ebay, I picked mine up for $65
Old Mar 24, 2002
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
Don't cut it, you can see perfectly fine through the white, it looks better too
Old Mar 25, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
I just put mine in yesterday and it looks sweet. [IMG]i/expressions/face-icon-small-smile.gif[/IMG] The lights show through fine, but one word of advice is you may wanna get some double-sided tape to have everything line up perfectly. I had some problem with the gauge shifting a bit when I put the coverings back onto the gauge cluster. And if your friend is getting the gauges with that 'control tab' for adjusting the colors/brightness (1 green and like 4 shades of blue), its really bright when you have it at a high setting. What I did was snake the tab behind the stearing column and had it come out into the coin tray. Now I can see what I'm grabbing at when I come to the tolls.
-Kre
Old Apr 1, 2002
Ritz's Avatar
Ritz is an unknown quantity at this point
if the tape doesn't work to good for you I used super glue.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ThatGuy913
Sep 28, 2015 05:35 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
