Dezod stopping power is now here!
7thgen Power Maker
Well it's time we let the cat out of the hat and tell you that we now have Dezod brand performance brake pads.
They are X-rated.
* High metal and carbon content for extreme heat and load conditions.
* Low resin content for long life and maximum fade resistance.
* Original equipment style hardware.
* Original equipment style noise dampening shims for quiet performance.
* Slotted and chamfered just like OE for smooth, quiet engagement.
* Operates best under severe conditions and possesses a higher heat range than most pads.
* Dual layered friction for maximum sheer strength under severe pressures.
Fattore di Frizione! Friction factor is the translation and meaning behind these wonderful pads. They have an excellent initial bite, but retain the street properties of OEM with quiet stopping, less dust and squeeling. Direct fit for your application with no modifications needed. The wide heat range on these pads make them ideal for the daily driven weekend track warrior.
Stop obscenely fast!
Dezod Motorsports. Dezod Motorsports X-Rated Front Brake Pads-Civic 01-05 EX/DX/LX/HX CPE & SDN
They are X-rated.
yes i want to know as well, i usually get hawks for around the same price (53 or so) if they are closely comparable im going to have to pick up a set
7thgen Power Maker
They out bite the HAWKs in IMHO. These pads are awesome and a cut above the Hawk HPS, but not quite to a full blown race pad. They have a great bite cold or super warm, which is a plus.
I just burnt my tongue
nice pads...but im sticking with the axxis ultimate ceramic pads...maybe next set of brakes im gonna get the brembo sport kit with drilled rotors and brembo pads
7thgen Power Maker
Drive a good ferro-carbon or high metallic substrate pad and you will never go back to Axxis. Axxis are good, but I have rode better for sure.
7thgen Power Maker
nice....
I went to your website to order a set along with some brembo blanks. Why do you want so much for the rotors? Everyone seems to be seling those rotors for $32 each. Let me know if you are willing to work on the price of the rotors.
jbradley4809
Apr 7, 2017 04:23 AM
silentz
Jun 17, 2015 10:21 PM
h4ldol
Jun 3, 2015 03:26 PM
trellex
May 24, 2015 04:39 PM
