Sponsored by:
Sponsored by: CARiD
Replacement key
Old Feb 8, 2007
chopper202's Avatar
chopper202 is an unknown quantity at this point
Replacement key
I just got a key cut for my 98 civic but the key I got it cut from is the one with the imobliser in it, Am I able to start the car with the key I got cut or will it stuff up the imobliser and cause damage I can't undo. I know the key can open the car doors but im not sure about anything else????
Old Feb 8, 2007
PennyKnotOff's Avatar
if it has the immobilizer in it the car shouldn't start. never heard of it causing any damage though
Old Feb 8, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
A 98 civic does not come equipped with an immobilizer so as long as the key was cut properly. It will work.
Old Feb 8, 2007
chopper202's Avatar
Im in australia and my 98 hatchback did not come stock with imobliser but it was an option which is in my car so when ever i put the orignal key in it lets me use it but when i used the cut key the barrel turned but nothing happned and when I used the orignal it did not work and still dosent is there something I have to reset?????
Old Feb 8, 2007
chopper202's Avatar
Ok I rang honda to see why my car wouldnt start after using the cut key, and he told me that because mine has an imobliser you have to use the orignal key other wise it thinks some one is trying to nik off with it by using a screw driver or something. All because it dosent have the chip or something in the key... So I pretty much have to carry two keys around if I want to use it...
Old Feb 8, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
why would you need to carry two keys? just carry one key that works? A cut key will work for the doors and trunk, because there is no immoblilzer (makes sense), but it will not for starting the engine
Old Feb 9, 2007
chopper202's Avatar
The reason I would have to have 2 keys was that when I go surfing (thats y i got it cut) I can not take the imobliser key in the water cose it says not to submerge in water so i would leave it in the glovebox and take the cut key and put it in my wetsuit pocket so i can get back in the car...
Old Feb 11, 2007
rice4lyfe's Avatar
then its probably perfect for you then. The cut key would just open doors and stuff, and your real key would start the engine
CarStuff
Dec 6, 2020 12:52 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
civic_gt
Apr 19, 2015 08:15 AM
SSMatey
Apr 13, 2015 06:09 PM
thesushiboy
Apr 12, 2015 02:54 AM
