I've heard different views on this topic...
In reference to racing with radial tires, is it actually better to lower psi down to 19 or 20 psi OR should I just leave the pressure alone at 32-34 psi, whatever it's currently at. The majority have said to lower it, but a couple of senior members on this forum (can't remember who) said that more traction would be lost if I lowered the psi in my radial tires....what do you guys think? [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
It would make sense to me to lower the presure....... my psi is @ 45........I'd drop it to 35.........
whateve[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
a senior mem here said a while ago that lowering the psi would make the radial tire "cup" or something along those lines which would actually lead to less tire in contact with the pavement. something like that but plz need advice [IMG]i/expressions/face-icon-small-cool.gif[/IMG]
When you lower the pressure, more of the edge might be touching, but the tread arches and the middle of it comes up. If you over inflate, the tire balloons so that the middle becomes the only par touching and if you have proper pressure, you have no arches or ballooning, the the tread is making proper contact with the road
For racing 32-34 PSI is best.. Why.. best controll, most sidewall stailibity most rubber on the pavement. For Straighline dragging though it's different because when pulling out the tire flattend iteself out and you get more rubber to the road.. but in turns you you would have no grip and would risk ripping the rubber from the rim....
I was a tire installer for 2 years..not pretty to see what happens with underinflated tired on the highway through a turn [IMG]i/expressions/face-icon-small-smile.gif[/IMG]..Pop goes the tire.. flip goes the vehicle..
Cheers
Mohawk
Cheers
Mohawk
Ummm... Radials shouldn't be dropped, it is true about the cupping of tire, which right out of the hole will give you better traction when they flatten, but street racing and roadracing keep it the way the factory says.
cferry7
Oct 18, 2015 06:32 PM
brags
Oct 2, 2015 05:53 AM
curaze
Sep 22, 2015 08:27 AM
MichaelLW
Sep 14, 2015 07:15 AM
